Hard vs Soft F-150 Truck Bed Cover: What You Need to Know Before You Buy
Time to read 9 min
Time to read 9 min
Soft tonneau covers are lighter, generally less expensive, and faster to install, which makes them a solid option for F-150 owners who haul frequently and need quick bed access
Retractable hard covers eliminate the main tradeoff between security and full bed access, giving you both in one setup
Your choice should come down to how you use your F-150, where you drive, and how often you're loading oversized cargo
WOLFBOX Gear's SmartSlide electric retractable bed cover is purpose-built for the Ford F-150 and offers one-touch operation with a weatherproof aluminum build
If you own an F-150, you've probably thought about picking up a bed cover at some point. They protect your gear from weather and theft, they can help with fuel efficiency, and they give the truck a more finished look. But here's where most people get stuck: hard or soft?
It's not a simple question. Both types have real strengths, and the right f150 truck bed cover for your situation depends heavily on how you actually use the truck. We put this together to give you a straight-up comparison so you can make the call with confidence.
This is where the two types separate most sharply. Soft covers are made from vinyl or canvas, and a sharp blade can get through that material. Most soft covers use snaps, Velcro, or clamps to stay closed. They're not designed to stop someone who really wants in. They'll keep honest people honest and protect your gear from plain sight, but that's about as far as the security story goes.
Hard covers are a different situation. Aluminum, fiberglass, and polycarbonate panels can't be cut, and they lock in place. Many hard covers integrate directly with your F-150's tailgate lock, so the whole bed becomes a secured compartment when both are engaged. If you park in urban areas, leave tools in the bed regularly, or head out on trips where your truck sits in trailhead parking lots for hours, this matters a lot.
Soft covers have gotten much better in recent years. Quality vinyl with UV-resistant coating and reinforced stitching can hold up through several years of daily use. But they're still working against time and the elements. UV exposure causes fading and cracking, heavy snow can push down on the material, and the general wear of rolling or folding the cover repeatedly adds up.
Hard covers are built to outlast them. Aluminum doesn't fade, crack, or tear. It handles heat in the Arizona desert, ice and salt on winter roads in the upper Midwest, and the relentless rain of the Pacific Northwest without showing much for it. If you're keeping this truck for the long haul, a hard cover is the better long-term investment.
Soft covers offer a clean, low-profile look that suits most F-150 builds well. They sit close to the bed rails and don't add much visual bulk. Most are black, which works with just about any truck color. It's a functional, understated look.
Hard covers tend to look more integrated and purpose-built. Retractable and folding aluminum covers sit flush with the bed rails and give the truck a more finished, custom appearance. If you want the F-150 to look like it was spec'd from the factory with the cover on, a hard cover gets you closer to that. Some styles are available in different finishes as well, giving you a bit more control over how the truck presents.
Most soft tonneau covers clamp directly to the bed rails with no drilling and no permanent modifications. It's a job most F-150 owners can knock out in under an hour with basic hand tools. And if you need to remove the cover entirely, it comes off just as easily.
Hard covers take more time and, depending on the style, more hardware. Retractable covers like the SmartSlide have a more involved install because of the canister and track system, but they still mount without drilling. If fast installation or the ability to easily swap covers is a priority, soft is the simpler path.
Soft covers roll or fold out of the way fast. If you're loading lumber, throwing tools in, or dropping a dirt bike in the bed before hitting the trails, a soft cover gets out of your way quickly. There's nothing heavy to prop open or stow.
Hard covers vary a lot by style here. A folding hard cover gives you sections of bed access, but when all panels are folded up, they stack at the front and eat into usable bed space. A single-hinged lid opens the whole rear half but needs to stay propped. Neither is ideal when you need the full bed open regularly.
That's the problem retractable hard covers solve. A retractable cover slides completely into a low-profile canister at the cab when you need the bed open, and locks back down across the full width when you want protection. You get the security of a hard cover without sacrificing bed access.
Our SmartSlide electric retractable bed cover for the Ford F-150 adds one-touch electric operation on top of that. Press the button, the cover retracts. Press it again, it locks back down with a full perimeter gasket seal. For owners who haul regularly but don't want to give up security when the truck is parked, it's the setup that removes the tradeoff entirely.
Soft Bed Cover |
Hard Bed Cover |
Deployment |
Roll-up or fold-up |
Fold, flip, or retract |
Security |
Low to moderate |
Moderate to high |
Weather sealing |
Good |
Better |
Weight |
Light (8 to 20 lbs typical) |
Heavier (30 to 80-plus lbs) |
Ground clearance impact |
Minimal |
Minimal (retractable canister adds 2 to 3 inches of height at cab) |
Installation complexity |
Simple, under 1 hour |
Moderate; varies by style |
Best for |
Frequent haulers, tighter budgets |
Security-focused use, harsh weather regions |
This comes up often, and the honest answer is yes, though the improvement varies. The U.S. Department of Energy's fueleconomy.gov points out that aerodynamic drag is one of the biggest factors in fuel consumption at highway speeds. An open truck bed creates a turbulent air pocket behind the cab that increases drag noticeably.
Research reviewed by the Society of Automotive Engineers (SAE) has looked at how different cover designs affect drag on pickup trucks. Results differ depending on cover geometry, truck model, and driving conditions, but the consistent finding is that covered beds reduce aerodynamic drag compared to open beds. For highway-heavy drivers, that adds up over time.
Hard retractable covers, when closed, tend to sit flat and low, which can be slightly more aerodynamic than a rolled soft cover that sits raised above the rail. But both are better than running with no cover at all.
There's no single correct answer, but it's not hard to figure out if you think about how you actually use your F-150.
Go with a soft cover if:
You haul frequently and need fast, unobstructed bed access on a regular basis
Your budget is a factor and you want solid protection without a big investment
You want a quick, tool-light installation
You don't store high-value gear or equipment in the bed overnight
Go with a hard cover if:
Security matters and you keep tools, off-road gear, or equipment in the bed
You drive regularly in wet or dusty conditions like the Pacific Northwest, the Gulf Coast, or the desert Southwest
You want a cleaner, more built-out look
You're open to spending more for a setup that lasts longer and protects better
And if you fall into that second category but you still haul a lot? That's exactly where a retractable hard cover makes sense. You don't have to give up bed access to get security. With a retractable setup, both the cover and your full bed are available whenever you need them.
We didn't build the SmartSlide as a generic bed cover and call it a day. It's engineered to fit the Ford F-150 specifically, so the fit is exact and the install is clean. The aluminum alloy frame and reinforced slat system hold up to real-world use, whether that's desert heat in Arizona, salty winter roads in the upper Midwest, or the constant wet of a Pacific Northwest winter.
The electric motor runs the cover open and closed with one button press. There's a full weatherproof seal along the bed rails and the tailgate edge. And when you need the bed fully open for a big haul, it retracts completely into the low-profile front canister, out of your way entirely.
Sound like what your truck's been missing? Browse the full SmartSlide lineup on our retractable bed cover collection page and find the configuration that fits your F-150.
If you're ready to move beyond a basic soft cover and want a setup that's actually built for the way you use your truck, we'd love to help. At WOLFBOX Gear, every cover comes with guaranteed fitment, so if it doesn't fit your rig, it's on us. Our team is available Monday through Friday from 9AM to 7PM at +1 888-432-7508 or by email at gears@wolfbox.com. We're truck people, and we're here to help you figure out the right fit.
Hard covers use rigid aluminum, fiberglass, or polycarbonate panels and offer better security and weather sealing. Soft covers use vinyl or canvas over a lightweight frame and are easier to install and typically less expensive. The best choice depends on your security needs, how often you haul, and where you drive.
Yes, in most cases. Covering the bed reduces aerodynamic drag, especially at highway speeds. Both hard and soft covers provide some improvement over an open bed. Hard retractable covers with a flat closed profile tend to be slightly more aerodynamic than rolled soft covers.
A sharp blade can cut through most vinyl soft covers. They're built to keep out weather, not to resist forced entry. If you're storing tools, equipment, or anything valuable in your bed overnight, a hard lockable cover is a much better option.
Soft covers typically install in under an hour with hand tools and no drilling involved. Hard covers like the SmartSlide take a bit more time but don't require permanent modifications to your truck. The mounting system clamps to the bed rails, which keeps everything reversible.
In most cases, yes. Most tonneau covers clamp to the bed rail and don't interfere with spray-in or drop-in bed liners. That said, thicker drop-in liners can sometimes affect the fit, so it's worth confirming compatibility with the specific cover you're looking at before purchasing.
For F-150 owners who want both security and full bed access, it's usually worth it. Retractable covers don't force you to choose between having the cover on or having an open bed. Electric retractable models like the SmartSlide add the convenience of one-touch operation, which makes a noticeable difference day to day.
A hard cover with a sealed gasket running the full perimeter of the bed will outperform most soft covers in heavy rain. Retractable aluminum covers with a full weatherproof seal along the rails and tailgate edge are among the best options for wet climates like the Pacific Northwest, Gulf Coast, or anywhere that gets frequent storms.
