WOLFBOX GEAR ENGINEERING
ELEVATE THE RIDE
Step in with ease. Smart tech that welcomes you and your family every time.
SMART
DEPLOY
Deploys in 1.5s. High-torque system responds instantly, then tucks away cleanly.
ALL
WEATHER READY
Relentless IP67 sealed motor. Engineered to literally crush through thick ice and frozen mud.
660LBS
LOAD LIMIT
6063-T5 aircraft-grade aluminum. Rock-solid support for your heaviest workloads.
LED
LIGHT SYSTEM
Integrated ambient LEDs illuminate the 6-inch anti-slip surface for secure low-light footing.
ULTRA-TOUGH. ULTRA-SMART.
ULTRA-STEALTH.
Unleash the professional-grade potential of your rig. Custom-engineered for a flawless fit, our Power Running Board System is built to survive the absolute worst elements. Stop struggling, start stepping.
  • Relentless Motor & Arctic-Tested (-40°F)
    Our IP67 fully sealed motor delivers massive torque to break right through heavy ice buildup and frozen mud, ensuring reliable deployment during brutal Snow Belt winters.
  • High-Clearance Stealth Profile
    Retracts flush under the rocker panel for a clean, in-line look—specifically designed to preserve your truck’s high ground clearance and aggressive aesthetic.
NO-NONSENSE PERFORMANCE.
BUILT TO LAST.
Engineering that respects your truck's integrity. We focus on seamless integration and pro-grade durability, providing a stepping solution that works as hard as you do, day in and day out.
  • Precision Direct-Fit (Zero-Drill)
    100% bolt-on DIY installation utilizes existing factory mounting points for a seamless setup that respects and protects your truck’s frame.
  • 5-Year Limited Warranty
    No-nonsense power for those who demand excellence. We back our steps with a 5-year replacement warranty against structural and workmanship defects.
SELECT YOUR FITMENT
Precision engineered for specific truck and SUV models. Choose yours.
We've Got Your Back
Do I need to drill holes or splice wires to install this electric truck bed step?
No drilling or complicated wire splicing is required. Our electric step features a pre-assembled motor and utilizes an innovative CAN bus wiring system. This plug-and-play engineering installs a remarkable 60% faster than traditional magnetic sensor alternatives, eliminating guesswork and safely upgrading your vehicle without any permanent modifications.
Will the motorized step mechanism freeze in winter or fail in deep off-road mud?
The step is powered by an IP67-rated motor, making it fully sealed against water and dust ingress. It functions flawlessly even when temporarily submerged. Furthermore, the high-torque design provides the aggressive power needed to instantly crush ice on contact, ensuring reliable automated deployment during the harshest winter weather.
What is the maximum load capacity, and is the electric platform stable under heavy impact?
Engineered for extreme strength, this electric step boasts a massive 660 lb load capacity. It is constructed from high-strength aluminum alloy to prevent bending or sagging. Coupled with the high-torque motor, the platform ensures highly stable and reliable support, even under dynamic impact when loading heavy construction materials.
How do I clean and maintain the electric step to prevent it from jamming over time?
Maintenance is incredibly simple thanks to the fully sealed IP67 motor. Simply flush the exterior aluminum brackets with water to remove abrasive mud or winter road salt. Never apply wet, oil-based lubricants like WD-40 to the joints; use only a dry PTFE spray to prevent dirt accumulation and gear binding.
Will installing these electric running boards reduce my truck's ground clearance off-road?
No, they actually protect your clearance. Unlike traditional fixed steps that constantly hang low and catch on obstacles, our motorized boards tuck seamlessly against the vehicle's rocker panels when doors are closed. This preserves your truck's maximum factory ground clearance while maintaining a sleek, lifted aesthetic.
Do these power steps drop lower than standard factory fixed running boards?
Yes, they are specifically engineered for enhanced accessibility. When deployed, the electric articulating hinges allow the step to drop significantly lower to the ground than rigid factory boards. This creates a much safer and more natural stepping height, which is especially beneficial for lifted trucks or shorter passengers.
