WOLFBOX GEAR ENGINEERING
AIR THE WILD
Total control at your fingertips. Air up fast and manage tire pressure like a pro.
100%
DUTY CYCLE
Engineered to run at full capacity for 120 minutes straight @40PSI. No breaks needed.
TWIN
MOTOR SYSTEM
Twice the speed, half the wait. Unstoppable airflow to get you back on the trail fast.
100HRS
TORTURE TESTED
Industrial-grade aluminum & stainless valves built to handle blistering high heat.
3-IN-1
INFLATOR GUN
Check pressure, air up, and air down effortlessly. Features our patented quick-connect nozzle.
NO GAPS. NO BREAKS.
NO DRAMA.
PROVEN DATA: 0-40 PSI IN 3 MINUTES FLAT Stop waiting around. Class-leading inflation speed when you need it most.
Experience uninterrupted power with the HyperFlow X On-Board Air Compressor. Built for real off-roaders who need to inflate massive mud-terrain tires—or an entire convoy—without waiting around.
  • True 100% Duty Cycle
    Don't sit on the shoulder waiting for your gear to cool off. Our system runs at full capacity for 120 minutes straight, delivering relentless airflow exactly when you need it.
  • Relentless Dual-Motor Airflow
    Twice the speed means less downtime. Whether you're airing up after a long day on the rocks or helping out a buddy on the trail, it keeps your adventure rolling.
EXTREME DURABILITY.
PRO-GRADE PRECISION.
Push your rig to the limit without the risk. From heavy-duty internals to our patented air delivery tools, every component is engineered to handle blistering heat and harsh environments.
  • Triple-Layer Active Safety
    A smart system constantly monitors performance to protect both the compressor and your vehicle. Backed by a 3-Year Warranty for total peace of mind on the toughest trails.
  • Patented Quick-Connect & 3-in-1 Gun
    Seamlessly check pressure, air up, and air down. Our exclusive quick-connect nozzle features a heat-resistant sleeve that snaps on securely and releases instantly—no twisting, zero leaks.
  • Precision Dust Removal Accessory
    Done kicking up dirt? Swap to the included air blow gun to blast stubborn dust out of your AC vents, center consoles, and hard-to-reach cab corners.
HyperFlow X Dual Motor Air Compressor components and inflator gun
We've Got Your Back
OFF-ROAD AIR IN ACTION
How fast can the 12V twin-motor air compressor inflate large off-road tires?
It is incredibly fast. The 12V twin-motor, dual-cylinder design delivers massive high-volume airflow capable of inflating a massive 37-inch tire in under 3 minutes. This extreme efficiency dramatically reduces your wait time, getting you and your convoy back on the trail significantly faster than standard single-motor units.
Can I run this on-board air compressor continuously without stopping for cool-down breaks?
Yes, absolutely. This compressor features a true 100% duty cycle, meaning it can run continuously for up to 120 minutes without requiring cool-down periods. You can easily power through tire inflation for your entire off-road convoy or run pneumatic air tools effortlessly without fearing thermal shutdown.
What is the advantage of using the optional 4-tire inflation hose kit?
The quad-hose system perfectly equalizes the air pressure across all four tires simultaneously. Instead of squatting at each wheel, you simply connect the hoses and let the high-volume twin motor work while you sit comfortably in your cabin. It dramatically speeds up airing up or deflating.
Will the air hose quick-connect chuck burn my hands after running at 150 PSI?
No, you will not burn your fingers. The compressor features a patented Anti-Scald Protection system (Patent No. 10,166,825 B2) with an exclusive quick-connect chuck. This innovative engineering allows you to safely and immediately detach the hose right after heavy, high-heat use without twisting or burning your hands.
Is the compressor durable enough to withstand extreme off-road conditions and engine bay heat?
Yes, it delivers military-grade durability. Built with hard-anodized aluminum cylinders and Teflon-impregnated piston seals, the unit actively reduces friction and efficiently dissipates extreme heat. This robust construction ensures reliable, long-lasting performance even when exposed to harsh environments or mounted inside a hot engine compartment.
How does the compressor prevent overheating or motor burnout during long inflation sessions?
You can push your gear to the absolute limit safely. The compressor is engineered with Smart Active Monitoring, featuring an automatic heat protection circuit and an integrated over-pressure valve. This intelligent system proactively manages internal temperatures and pressure loads, guaranteeing the twin motors will never suffer catastrophic burnout.
