How GMC Power Running Boards Improve Access for Passengers
Published on
Time to read 10 min
  • A GMC Sierra sits tall from the factory, and lift kits, AT4 trims, and bigger tires push that first step even higher.
  • GMC power running boards drop a wide step down when a door opens, then tuck back under the rocker when it closes.
  • Kids, older passengers, shorter adults, and anyone climbing into the back of a Crew Cab get the biggest benefit.
  • For passenger safety, look for a wide anti-slip tread, LED lighting, anti-pinch auto-stop, and a short delay before the step retracts.
  • Fitment depends on your Sierra's model, cab, and body style, so confirm it before you buy.
Ever watched someone grab the door frame, plant a knee on the sill, and haul themselves into a Sierra?
If you drive one, you've probably seen it more than once. Maybe it's your kids. Maybe it's a parent who doesn't love the climb anymore, or a buddy who rode along to the lake and nearly slipped off a wet rocker panel on the way back in.
GMC trucks are tall on purpose. That height buys you ground clearance, a good view of the road, and room for bigger tires. Nobody's complaining about that part. But it also turns the first step into a real reach for a lot of the people you drive around.
That's the problem GMC power running boards solve. Below, we'll cover how they work, who they help most, which features matter for passenger safety, and what to check before you pick a set for your Sierra.
Why Getting Into a GMC Sierra Can Be a Stretch
Start with a stock Sierra 1500 Crew Cab. Even with no upgrades, the door sill sits high enough that shorter passengers end up stepping on the rocker or climbing in knee first.
Now add a lift. GMC's AT4 and AT4X trims come with a 2 inch factory installed suspension lift, and plenty of owners go further with aftermarket kits and 35 inch tires. Every inch of lift is one more inch your passengers have to climb.
Heavy duty trucks raise the bar again. A Sierra 2500 HD or 3500 HD generally sits taller than a half ton, so the gap between the ground and the cab gets bigger.
And the back seat is where it really shows.
In a Crew Cab, the people riding in back are often the ones who struggle most with a tall step: young kids, older relatives, or a coworker juggling a lunch cooler and a hard hat. Factory steps and fixed boards help some, but a fixed step has to sit high enough to stay out of the way on the trail. So it's usually a compromise between access and clearance.
How GMC Power Running Boards Work
The idea is simple. Open a door, and the step swings down and out. Close the door, and it folds back up under the rocker panel.
Three parts make that happen:
  • A door signal. The system needs to know the moment a door opens. Better kits read that signal from the truck's CAN bus network, which avoids the alignment and weather problems that come with magnetic door switches.
  • A control module. The ECU takes that signal and tells the motors when to deploy and when to retract.
  • A motor and linkage on each side. These swing the board down to step height and back up to its tucked position.
On the WOLFBOX Gear Power Running Boards for the newer Sierra 1500 and Sierra HD, the board deploys in about 1.5 seconds and waits 3 seconds after the door closes before tucking back up. Depending on your Sierra, the door signal comes from the OBD-II port under the dash or from the radio module behind the passenger side glove box.
Why does that matter for passengers? Because the step is already down by the time someone swings a leg out. Nobody waits for it, and nobody has to remember to push a button.
Who Gets the Most Out of GMC Power Running Boards
Kids and Families
Little kids can't climb into a lifted truck alone. Not without a boost, anyway. A deployed step gives them a halfway landing, so they can climb in on their own instead of being lifted every time.
It helps parents too, and anyone who's leaned across a back seat to buckle a car seat knows how awkward that gets from the ground. Standing on the step puts you closer to the seat and takes a lot of strain off your back.
Older Passengers and Anyone With Sore Knees
Falls are a real concern as people get older. According to the CDC, about 1 in 4 adults age 65 and older reports a fall each year. A high, awkward climb into a truck is the kind of move a lot of older riders would rather skip.
A lower, wider landing breaks that climb into two smaller steps. For most passengers with stiff hips or bad knees, that's the difference between dreading the ride and not thinking about it at all.
Shorter Adults
You don't have to be a kid to find a lifted Sierra hard to get into. Shorter drivers and passengers often hop in or hook a knee on the seat. A step at the right height lets them walk in instead.
Work Crews, Hunters, and Muddy Boots
Some trucks see a dozen door openings before lunch. On a Midwest job site or a muddy hunting lease in Texas, that's a lot of boots on a slick rocker panel. A dedicated step with real grip gives everyone a solid place to land, and it keeps mud off the paint on your sills.
Passenger Safety Features to Look For
Not every power step is built with passengers in mind. If the people riding with you are the main reason you're shopping, these are the features that matter.
A Step Height That Actually Helps
Step drop is the big one. WOLFBOX Gear Power Running Boards list a 13 to 15 inch step drop on full size trucks, depending on the model. On a lifted Sierra, compare that drop to your truck's ride height before you buy. If the deployed step still sits high, it won't do much for the passengers who need it most.
A Wide, Grippy Tread
Narrow tube steps can be tough to stand on with work boots or wet sneakers. Look for a flat, wide platform. Our GM kits use a 6 inch anti-slip surface on 6063-T5 aluminum, rated for up to 660 lbs, so an adult with a full pack can stand on it without it feeling flimsy.
Lighting for Night Pickups
Dark driveways. Trailhead lots at 5 a.m. Parking spots outside a high school football game. Built-in LEDs that come on as the step deploys show passengers exactly where to put their feet, which is a small thing until somebody misses the step in the dark.
Anti-Pinch and a Retraction Delay
Kids are quick, and they don't always clear the step before the door shuts. An anti-pinch feature stops the board when something's in the way. Pair that with a 3 second delay before the board retracts, and nobody gets caught mid-step if a door closes a little early.
All-Weather Access, From Arizona Heat to Michigan Winters
A step that only works on nice days doesn't help much. Your passengers need it most when it's dark, cold, or wet.
Our GM kits are rated to operate from minus 40°F up to 176°F. That covers a January morning in Minnesota and a parking lot in Phoenix in July. The high-torque motor is designed to push through ice and packed snow buildup, which matters across the Snow Belt, where a frozen step is the last thing you want with a toddler on your hip.
Water and grit are the other enemies. Motors and connectors sit right behind the front tires, where they get hit with slush, road salt, and gravel all year. Look for an IP rating defined under IEC 60529, the international standard for ingress protection. An IP67 rating means the motor is dust tight and can handle temporary submersion, which fits a truck that sees creek crossings and salted highways.
Even with good sealing, it's smart to rinse the linkage after winter driving. Salt left sitting on any moving part will slow it down eventually.
Power Running Boards vs. Fixed Boards vs. No Step
Wondering how much of a difference power boards actually make for passengers? Here's how the three setups usually compare on a full size GMC.
Fixed Running Boards or Nerf Bars
No Step
Step height for passengers
Drops lower when a door opens
Fixed height, often a compromise
Full climb from the ground
Ground clearance
Tucks up close to the body when retracted
Hangs below the rocker full time
No impact
Night visibility
Often includes LED step lights
Usually none unless added
None
Rear door access on Crew Cab
Runs the length of the cab
Depends on board length
None
Mud and snow
Step swings down fresh each time
Packs with mud and ice
Rocker panel takes the hit
Brackets plus wiring and a door signal
Brackets only
None
Best for
Families, lifted trucks, all-weather daily drivers
Basic step on a stock height truck
Owners who rarely carry passengers
Do GMC Power Running Boards Hurt Ground Clearance?
Not when they're designed to tuck tight. That's one of the main reasons owners pick power boards over fixed ones.
A fixed board has to hang low enough to be useful as a step, which means it hangs low on the trail too. A power board only drops when a door opens. Once you're rolling, it sits high and close to the body, so your breakover angle on a rocky two-track in Colorado stays about where it was. We cover this in more detail in our guide on how power retractable running boards improve ground clearance.
Fitment and Installation for Your Sierra
Here's where a lot of buyers trip up. GMC changed the Sierra over the years, and a power board has to match your exact model, cab, and body style.
WOLFBOX Gear Power Running Boards are designed for off-road use and are compatible with a wide range of vehicles, including trucks, Jeeps, and SUVs. For the Sierra, we offer two kits. The WOLFBOX Gear Power Running Boards for the newer Sierra 1500 and Sierra HD fit 2022 and newer Sierra 1500 Crew Cabs plus 2024 and newer Sierra 2500 HD and 3500 HD Crew Cabs, diesel models included. That kit doesn't fit the 2022 Sierra 1500 Limited.
If you've got an earlier truck, the WOLFBOX Gear Power Running Boards for earlier Sierra 1500 and Sierra HD Crew Cabs cover 2019 to 2021 Sierra 1500 Crew Cabs, 2020 to 2023 Sierra 2500 HD and 3500 HD Crew Cabs, and the 2022 Sierra 1500 Limited.
Both kits bolt to factory mounting points with no drilling. Install time is estimated at one to two hours for most DIYers with basic hand tools. You'll mount the brackets, route the harness to the battery, mount the ECU, connect the door signal, and cycle test every door before you call it done. Our GMC Sierra power running boards installation guide walks through each step, including where to find the signal wires on your truck.
Not sure which kit is yours? Select your vehicle on our site and you're covered by the WOLFBOX Gear Guaranteed Fit promise. If the part doesn't fit the truck you selected, you can send it back within 30 days.
Passengers aren't the only ones climbing, either. If you're in and out of the bed all day, the WOLFBOX Gear Retractable Bed Step for the Sierra 1500 adds a drop-down step for bed access with a no-drill install.
Find GMC Power Running Boards That Fit Your Sierra
If the people you drive around are working too hard just to get in the truck, a power step is one of the most practical upgrades you can make. Add your Sierra and browse WOLFBOX Gear power running boards matched to your exact model and cab. Got a question about fitment or install? Our specialists are a call or email away at 888.432.7508 or gears@wolfbox.com.
Step Up. Get Out There.
Are power running boards worth it on a GMC Sierra?
For most owners who carry passengers, yes. Power running boards give kids, older riders, and shorter adults a lower, wider step when a door opens, then tuck away so you keep your ground clearance. They're especially useful on lifted Sierras and AT4 trims.
How far do GMC power running boards drop?
It depends on the brand and model. WOLFBOX Gear Power Running Boards list a 13 to 15 inch step drop on full size trucks. Compare that number to your truck's ride height, especially if it's lifted.
Do power running boards help back seat passengers in a Crew Cab?
Yes. Crew Cab power boards run the length of the cab, so there's a step at both the front and rear doors. That makes a big difference for kids and older passengers who usually ride in back.
Do GMC power running boards work in snow and ice?
Good ones do. Look for a motor rated for cold weather and an IP67 waterproof rating. WOLFBOX Gear Power Running Boards are rated to operate down to minus 40°F, with a high-torque motor designed to break through ice buildup.
Do you have to drill to install power running boards on a Sierra?
Not with a vehicle-specific kit that uses factory mounting points. WOLFBOX Gear kits for the Sierra bolt on with no drilling and typically take one to two hours to install.
Will power running boards fit a Sierra Double Cab or Regular Cab?
Our current GMC kits fit Crew Cab Sierras only. Always check your cab style and model year before ordering, since door openings and rocker lengths differ between cab configurations.
