Looking for a retractable step for my 2022 1500 Ram Rebel, any options available ?
Best Ram Truck Bed Step and Bed Access Upgrades
Time to read 9 min
Time to read 9 min
Retractable bed steps are the most versatile aftermarket option because they don't cut into your ground clearance when they're stowed.
Ram's built-in Multi-Function Tailgate step is a useful factory touch, but it's only available on certain trims and isn't designed for heavy daily use.
Hitch steps, power running boards, and side-mount options each serve different needs depending on how you use your rig.
Before buying, match the step to your actual use case. Jobsite hauling, weekend overlanding, and daily driving all have different demands.
If you've ever tried to heave a 40-pound cooler into a Ram 1500 bed without a step, you already know the problem. Sound familiar? Ram trucks sit at some of the highest bed heights in the full-size segment. The 1500's bed load floor lands around 21 to 22 inches off the ground depending on trim and suspension setup, and the 2500 and 3500 series go even higher. Without a solid bed access solution, you're either straining your back or doing some combination of climbing your rear tire and hoping for the best.
The good news is there are solid aftermarket options worth considering, from bolt-on hitch steps to power-assisted running boards. They're not all created equal, though. Here's a breakdown of what's available for Ram trucks, what separates the good options from the ones you'll regret, and what we think is actually worth your money.
Ram trucks are built for payload. Frame height, suspension geometry, and overall stance are all calibrated for hauling and towing, not for easy bed access. That's a fair trade-off for a work truck, but it creates a real ergonomic gap.
According to NHTSA research on vehicle ergonomics and cargo handling, step height and reach distance meaningfully affect how safely truck operators can load and unload cargo over repeated cycles. When you're doing that 50 or 100 times on a jobsite, it adds up fast.
The practical result for Ram owners: most people are working harder than they should be to get into and out of the bed. An aftermarket bed step isn't a luxury. It's a genuine quality-of-life upgrade.
There's no single right answer here. The best setup depends on how you use your truck and where you take it. Below are the four main categories of bed access upgrades and what each one does well.
This is the upgrade most Ram owners eventually land on. A retractable bed step mounts near the rear of the truck, usually via the hitch receiver or frame bracket, and extends when you need it and tucks away when you don't. It's the cleanest all-around solution for trucks that see both road and trail.
The big advantage over a fixed step is clearance. Fixed steps hang below the bumper and can catch on terrain with any kind of pitch to it. Steep driveway? Rocky approach on a Southwest desert trail? A fixed step becomes a liability fast. A retractable design stays out of the way until you actually need it.
Our Retractable Bed Step is built specifically for off-road use and works across trucks, Jeeps, and SUVs, not just Ram pickups. Deployment is foot-activated: a quick kick extends the step, and it retracts just as easily. No buttons, no fumbling with a latch while your hands are full of gear.
Weight capacity is a spec worth paying attention to here. Look for a step rated at 300 to 500 pounds. Anything lower isn't going to hold up under real-world use, especially when you're stepping up under load.
Installation on most retractable bed steps is also a genuine selling point. Most are hitch-receiver-mounted with no drilling required. You can have one on and ready to go in under 30 minutes.
Ram introduced an integrated tailgate step system on the 1500 starting with certain 2019 trims. It's a telescoping handle-and-step combo built directly into the tailgate. When it works, it's genuinely convenient.
But it has real limitations. The factory step isn't standard across all trims or model years, so many Ram owners won't have it at all. And because it's part of the tailgate structure, any wear or damage affects the whole gate. Replacement costs can be steep.
For casual daily use it's a fine solution if your truck came equipped with one. For anyone loading equipment regularly or working a jobsite, it tends to show wear faster than a dedicated aftermarket step will.
Simple, affordable, and effective on pavement. A basic hitch step slides into your 2-inch receiver and gives you a solid platform to step off of when loading the bed. Installation takes about 10 seconds. Cost is usually well under $100.
The obvious trade-off: it doesn't retract. A fixed hitch step hanging below your bumper is going to be a problem if you're wheeling. Approach angles, rocky terrain, rutted two-track roads in the Pacific Northwest, even a steep driveway entry can all become issues.
For a Ram that stays on pavement or gravel roads and sees mostly jobsite and highway use, a hitch step is a perfectly reasonable solution. For off-road use or overlanding, invest in the retractable.
Power running boards are more of a full-vehicle access upgrade than a dedicated bed step, but they're worth mentioning here because they also affect rear access.
They deploy automatically when a door opens and retract flush when it closes. For families, passengers with limited mobility, or anyone who's loading rear-seat occupants regularly, that kind of automatic deployment makes a real difference.
Our Power Running Boards are designed for off-road use and built for trucks, Jeeps, and SUVs. The retracted profile keeps your clearance clean on the trail, which matters more than most people think until they scrape a fixed board on a rock shelf.
Running boards won't fully replace a dedicated rear bed step for cargo loading. You'll still want a tailgate-area solution for that. But as part of a complete access upgrade for your Ram, they work well in combination with a bed step.
Retractable Bed Step |
Factory Tailgate Step |
Hitch Step |
Power Running Boards |
Ground clearance impact |
None when stowed |
None |
Yes (fixed) |
None when retracted |
Off-road friendly |
Yes |
Yes |
Limited |
Yes |
Installation |
Bolt-on |
Factory only |
No tools needed |
Wiring required |
Best for |
All-around use |
Newer Ram trims |
Pavement/jobsite |
Full-vehicle access |
Approx. price range |
$150 to $300 |
N/A (factory trim) |
$20 to $80 |
$1,000 and up |
Not sure which direction to go? These are the factors that actually matter once you're living with the upgrade day to day.
If your Ram goes anywhere off-road, clearance is non-negotiable. A fixed step or a low-hanging hitch accessory can catch on terrain your truck would otherwise clear without a second thought. The SAE sets standards for vehicle ground clearance and approach angle considerations that aftermarket accessories can directly affect. Retractable designs that fold completely behind the bumper or tuck above the bumper line solve this problem cleanly.
Don't skip this spec. Three hundred pounds is the minimum we'd consider for serious use. Four hundred to 500 is better, especially if you're stepping up while carrying tools, gear bags, or equipment. A step rated too low will flex and wear in ways you'll notice within a year of regular use.
Most hitch-mounted steps require zero drilling. Frame-mounted designs typically involve a handful of bolts and basic hand tools. Power running board installs take a few hours and involve some electrical work. Be realistic about what you're comfortable doing yourself, and whether you want to take the truck to a shop.
Textured platforms, diamond-plate tread, and rubberized coatings all matter when your boots are muddy. A smooth painted surface is fine on a dry day and dangerous on a wet one. For trucks working ranch roads in the Midwest or logging roads in the Northwest, the step surface finish is worth looking at closely.
Material finish matters for longevity too. Powder-coated steel is going to hold up better in salt and wet conditions than painted aluminum. If your Ram sees winter roads in the Northeast or upper Midwest, look for rust-resistant hardware throughout.
Real durability comes from honest materials, not marketing language.
If you're ready to upgrade your Ram's bed access, our truck steps collection has options built for real-world use. Whether you're loading gear on a trail in the Southwest or hauling materials on a Midwest jobsite, the right step makes your whole workflow easier and safer.
For a more complete access upgrade, our Power Running Boards pair well with a bed step and cover the full length of the vehicle. We also carry a full range of exterior accessories for Ram trucks and a wide range of other rigs.
WOLFBOX Gear backs every product with a guaranteed fit, 30-day hassle-free returns, and financing options if you'd rather spread the cost out. Questions? Reach our team at gears@wolfbox.com or by phone at +1 888-432-7508, Monday through Friday, 9AM to 7PM.
The Ram 1500's bed floor sits approximately 21 to 22 inches off the ground, depending on trim, cab configuration, and whether the truck has a factory leveling kit or lift. Ram 2500 and 3500 models typically sit higher due to their heavier-duty suspension setup.
A retractable bed step is the most versatile option for most Ram owners. It provides a stable step when needed and tucks away cleanly when you're driving, which matters a lot if you use your truck off-road or on rough terrain. Look for a step with a 300 to 500 pound weight capacity and a no-drill hitch-mount installation.
Some Ram 1500 trims include a Multi-Function Tailgate with an integrated step and handle, available on certain 2019 and newer models. It's not standard across all trims, though. Many Ram owners, especially those with older models or base configurations, add an aftermarket step for more reliable access.
A fixed hitch step will reduce your rear clearance and can affect your departure angle. A retractable bed step designed for off-road use deploys when needed and folds away when you're moving, keeping your angles clean. If you wheel your Ram at all, go with a retractable design.
Most hitch-receiver-mounted steps are straightforward DIY installs that take under 30 minutes and require no drilling. Frame-mounted designs may need basic hand tools and a bit more time. Power running boards involve some electrical work and usually take a few hours. Most truck owners with basic mechanical experience can handle any of these without a shop visit.
For regular use, 300 pounds is the bare minimum. If you're frequently loading heavy gear or stepping up while carrying equipment in your arms, a step rated at 400 to 500 pounds gives you more confidence and will hold up longer under daily use.
Most aftermarket bed steps use the standard 2-inch hitch receiver, which is common across Ram 1500, 2500, and 3500 models. Always check the fitment guide for the specific step you're considering, since bed height and bumper geometry can vary between trim levels and model years.
Comments
Would this retractable bed step fit on dodge Dakota?
I want more information on the products for a dodge TRX
