Power Running Boards vs Side Steps: What You Need to Know
Published on
Time to read 7 min
  • Power running boards retract automatically and don't reduce ground clearance when stored
  • Fixed side steps are simpler, cheaper, and easier to install, but they stay down permanently
  • For lifted trucks and off-road rigs, power boards are the clear winner for underbody protection
  • Fixed steps work well for daily drivers and urban use where clearance isn't a concern
  • Both mount to your truck's frame, but power running boards require an electrical connection during installation
If you've spent time shopping for truck running boards, you've probably noticed a pretty big gap between basic side steps and full power running boards. The price difference alone is enough to stop most people mid-scroll.
Is it worth it?
That depends entirely on how you use your truck. We hear some version of this question constantly from truck owners: "Do I actually need power running boards, or will a regular step do the job?" So let's break it down properly.
What Are Fixed Side Steps?
Fixed side steps, sometimes called nerf bars or static running boards, are exactly what they sound like. They bolt onto your truck's frame, sit at a fixed height, and give you a step to get in and out of the cab. That's it.
Most are made from aluminum or steel tubing with a non-slip step pad in the center. They don't move, don't need a power connection, and don't require any electronics to function. Installation on most trucks takes a couple of hours with basic hand tools.
The trade-off? They hang down from the rocker panels all the time. On a daily driver, that's not a problem. On a lifted truck running rocky switchbacks in Colorado or muddy backroads in the Ozarks, that low-hanging fixed step becomes a liability fast. It's the first thing to catch a rock or high-center on a berm.
What Are Power Running Boards vs Side Steps, Really?
Power running boards are a different animal. They're motorized, extending outward and dropping down automatically when you open a door, then retracting flush against the truck's body when you close it. When they're stored, they sit tight against the rocker panel. Out of harm's way. When deployed, they give you a wide, solid platform to step on.
Our WOLFBOX Gear power running boards are built specifically for this kind of use. They're compatible with most major truck platforms, from the Ford F-150 to the Chevy Silverado to the Toyota Tundra, and they're designed to handle the kind of daily use both families and trail runners put them through.
The motor, wiring, and controller are all part of the package. Installation takes more time than a fixed step, but the result is a board that doesn't eat into your ground clearance when you need it most.
Side-by-Side Comparison
Fixed Side Steps
Deployment
Automatic (door-triggered)
Always extended
Ground Clearance Impact
Minimal when retracted
Permanent reduction
Installation Complexity
Moderate (electrical connection required)
Simple (bolt-on)
Price Range
$800 to $1,200+
$100 to $400
Best For
Off-road rigs, lifted trucks, family haulers
Daily drivers, pavement use
That price gap is real. But so is the performance difference.
Power Running Boards: Pros and Cons
Pros
  • Don't reduce ground clearance when retracted, which matters a lot on technical trails
  • Automatically deploy when the door opens, making entry easier for passengers, kids, and older riders
  • Wide step surface, typically 6 to 7 inches, provides a stable, secure platform
  • Cleaner side profile when retracted since the boards tuck against the truck body
  • Vehicle-specific fitment options mean no modification is needed for most major trucks
Cons
  • Higher upfront cost than fixed steps
  • Require an electrical connection, which adds installation time
  • Motor and control module add components that need occasional inspection over time
  • If a motor fails, the board can get stuck in the deployed position until repaired
Fixed Side Steps: Pros and Cons
Pros
  • Bolt-on installation, usually 60 to 90 minutes with basic hand tools
  • No electrical work involved at any point
  • Low-maintenance since there are no moving parts to service
  • Lower cost makes them accessible for tighter budgets
  • Wide compatibility across most truck models
Cons
  • Permanently reduce ground clearance, even on lifted trucks
  • Can catch rocks, stumps, or trail obstacles during off-road use
  • No automatic deployment, so you're always stepping over or around them
  • Stick out from the truck body even when nobody's using them
Which Setup Fits Your Truck?
Here's where it gets practical. Not every truck needs power running boards.
If your F-150 mostly handles school pickup, grocery runs, and the occasional weekend camping trip, a solid set of fixed steps might be all you need. They're reliable, they'll hold up for years, and they won't strain the budget.
But if you're running a lifted Silverado or a Ram 1500 TRX and spending weekends on trails in the Southwest desert or crawling through Pacific Northwest logging roads, the math changes quickly. That fixed step hanging 8 inches below your frame rail isn't going to survive long before it meets a shelf rock.
Power running boards solve that problem. Retracted, they're tucked away and protected. Deployed, they give you a full-width platform to load gear, help passengers in and out, and handle whatever terrain you're working through.
Our Power Running Boards for the Ford F-150 (15-20) and Super Duty (17-19) are a great starting point if you're on an older F-Series. For Chevy and GMC owners, we've got model-specific options for the Silverado/Sierra 1500 (19-21) and 2500HD/3500HD (20-23), as well as the newer Silverado/Sierra 1500 (22-26) and 2500HD/3500HD (24-26).
Ram owners can find a direct fit for the Ram 1500 (19-24) and 1500 TRX (19-23). Toyota Tundra owners running the current gen can check out the Tundra (22-26) version. We also cover the F-150 Lightning and Super Duty (21-26) and the heavy-duty F-250/F-350/F-450/F-550 (20-22).
Each option is vehicle-specific. No guesswork, no drilling into places you shouldn't.
Ground Clearance: Why It Actually Matters
Ground clearance matters more than most people expect. You don't think about it until you lose it at the wrong moment.
The Society of Automotive Engineers (SAE) sets dimensional and performance standards for light trucks, and underbody clearance is a core part of that framework. A fixed step bracket hanging well below your rocker panel is the exact kind of component that gets ripped off on technical terrain.
Power running boards eliminate that exposure when retracted. It's one less thing to worry about when you're picking a line through rocks or crossing water. The NHTSA's vehicle safety resources also highlight how underbody clearance factors into overall light truck safety, particularly in off-highway and adverse terrain use cases.
For most off-road drivers, the clearance benefit alone justifies the price difference.
What to Expect During Installation
Fixed steps are a straightforward Saturday-morning job for most truck owners. You'll need a socket set and about two hours. Most mount to existing frame brackets or require minimal drilling.
Power running boards take more time. Plan on half a day. You'll need to route wiring to a door-trigger signal, usually by tapping into the door switch harness, mount the step bracket to the frame, and run through the deployment cycle to confirm everything's working.
We provide vehicle-specific installation guides for each platform. You can find the power running boards installation guide for the Ford F-150 (17-19) directly on our site, and all other guides are available from our main installation page. For most mechanically comfortable truck owners, it's a very doable DIY job.
Ready to Upgrade?
Fixed side steps are a solid, budget-friendly option for trucks that stay on pavement. Power running boards are a performance upgrade for trucks that actually get used.
If you're loading up a family of five out of a lifted Tundra at a trailhead, power boards change the whole experience. If your truck mostly lives in a parking garage, fixed steps get the job done.
Browse the full lineup of WOLFBOX Gear power running boards and find the version built for your specific truck. Every option comes with our Guaranteed Fit promise, so if it doesn't fit your rig, it's on us. Questions? Our specialists are available at 888-432-7508, Monday through Friday, 9AM to 7PM.
Are power running boards worth the extra cost over fixed side steps?
For most truck owners who go off-road or need easy access for family members, yes. The automatic deployment, protected ground clearance, and wider step platform make a real difference. If your truck stays on pavement and budget is the priority, fixed steps are a reasonable call.
Do power running boards reduce ground clearance?
When retracted, power running boards sit flush against the truck's rocker panel and don't meaningfully reduce ground clearance. Fixed side steps hang below the rockers permanently, which does reduce clearance on uneven terrain.
Can I install power running boards myself?
Yes, in most cases. It requires routing a wiring harness and connecting to a door switch signal, on top of the physical mounting work. Most truck owners with basic mechanical experience finish the job in four to six hours. Vehicle-specific installation guides are available on our site.
What's the weight capacity of power running boards?
This varies by product and model year. Check the specific product page for verified weight ratings. Don't rely on general estimates when it comes to load capacity.
How do power running boards work?
They use a small motor and actuator tied to your truck's door switches. When a door opens, the signal triggers the motor to extend and lower the step. When the door closes, the step retracts back flush with the body automatically.
Do fixed side steps work on lifted trucks?
They'll bolt on, but the geometry changes on a lifted truck. A step that sat at the right height on a stock truck might end up too low or at an awkward angle after a lift. Power running boards adapt better to lifted setups because they deploy to a consistent position regardless of ride height.
Can power running boards handle cold weather and winter driving?
Most quality power running boards are built to operate well below freezing. Extreme cold can occasionally slow the deployment cycle, but it's not a common issue in normal winter conditions. Check the product specs for confirmed operating temperature ranges specific to the model you're considering.
Comments
Do the power steps go lower than fixed steps? My truck has 6inch lift and has fixed step bars. 2023 Ram 1500.
Steven Gray
Looking for power steps for convenience and esthetics for a Dodge 1500 Big Horn
S pridgen
When will your new Wolfbox Power Running boards be avail. for the 2025+ Nissan frontier? also the Nissan Exterra will be coming out on the same frame as the Frontier.
Are they avail. now? if so, I would like to buy them now.
Bill Henley
