Extended Side Mirrors for Trucks: How Wide-Angle Convex Glass Improves Visibility
Time to read 8 min
Time to read 8 min
Wide-angle convex glass bends light to show more of the lanes beside you, which shrinks blind spots without changing the mirror housing.
Convex glass makes things look farther away than they are, so it takes a little practice before you trust it in tight spots.
For heavy towing, you'll usually want real extended mirrors. For daily driving and trail work, convex glass covers most visibility gaps.
The right mirror setup and adjustment matter as much as the hardware you choose.
Your stock mirrors probably worked fine until you hooked up a 30 foot travel trailer. Or added a 3 inch lift and 35s.
That's when the gaps show up.
Below, we'll break down what extended side mirrors for trucks actually do, how wide-angle convex glass works, and where each one makes sense.
Extended side mirrors, often called towing mirrors, place the mirror glass farther from the body of your vehicle. That extra reach lets you see down the sides of something wider than your truck. Think fifth wheels, boat trailers, horse trailers, or a utility trailer stacked with gear.
They come in a few main styles.
These attach over your existing mirror housing with straps, clamps, or a stretchy sleeve. They're cheap and come off in minutes. But fit varies a lot, and some shake at highway speed.
Here you swap the whole mirror assembly, and the head slides or flips outward when you tow. Install takes longer, since you'll usually pull the door panel.
Most full-size pickups offer tow mirrors as a factory option, and if you're buying new and tow often, that's simpler than retrofitting later.
A flat mirror shows a narrow slice of the road. Its field of view depends on the size of the glass and how far it sits from your eyes. On a big pickup, that slice often misses a car sitting just off your rear quarter panel.
Lifts make it worse. So do wider tires and fender flares.
Most drivers also aim their mirrors so they can see the side of their own truck. It feels natural, but it wastes a good chunk of the glass on a view you already know. Engineer George Platzer laid out this problem in SAE Technical Paper 950601, published through SAE International, showing how blind zones form between the side and center mirrors and how better aiming can shrink them.
Convex glass curves outward, like the back of a spoon. That curve gathers light from a wider angle and sends it to your eyes, so the same size mirror shows more of the road.
The flatter the curve, the closer the glass behaves to a standard mirror. A tighter curve shows more area but makes everything look smaller. Mirror makers describe this with a radius number. For example, glass marked R1200 has a curve radius of 1,200 millimeters, or about 47 inches.
So what's the catch? Objects in convex glass look smaller, and smaller looks farther away. A pickup that seems three car lengths back might really be two. In most cases, drivers adjust after a week or so. Still, we'd practice in an empty lot before trying a tight trailhead.
The federal mirror standard is FMVSS No. 111, found at 49 CFR 571.111. For passenger cars, it requires a flat driver side mirror and allows a convex passenger side mirror with an average curve radius between 889 mm and 1,651 mm (about 35 to 65 inches). That convex mirror also has to carry the line "Objects in Mirror Are Closer Than They Appear." You can find more on vehicle equipment rules through the National Highway Traffic Safety Administration.
Aftermarket glass is a different story, and rules can vary by state. Always check your local regulations before running any replacement mirror on public roads.
Not sure which one you need? Here's how they stack up on the things that matter most.
Convex glass wins for seeing the lane next to you. Cars in your blind spot show up sooner. Extended mirrors use flat glass in the main section, though many add a small convex spotter lens for this exact reason.
Extended mirrors win, and it's not close. If your trailer is wider than your truck, no amount of curve on stock-position glass lets you see around it. The glass has to physically move outward. Many states require a clear view of the road behind you while towing, so check your state's DMV rules before a long haul.
Convex glass keeps your factory mirror width. That matters in a drive-thru or a tight parking garage in downtown Denver. Extended mirrors stick out past stock, which means more chances to clip a pole.
On a tight Moab shelf road or a brushy Pacific Northwest logging route, wider housings catch limbs and rocks. Convex glass in the factory housing keeps your profile slim while giving you a better look at your rear tires and the trail edge.
Convex replacement glass is generally the easier job. Clip-on extensions are quick too. Full replacement tow mirrors take the most time and usually mean pulling the door panel.
Extended Towing Mirrors |
Wide-Angle Convex Glass |
Main benefit |
Sees past wide trailers and loads |
Wider view of lanes beside you |
Mirror width |
Sticks out past stock |
Stays at factory width |
Distance judgment |
Flat glass, true to size |
Objects look farther away |
Trail clearance |
More exposed to branches |
Factory profile |
Install effort |
Moderate to involved |
Generally simple |
Best for |
Frequent towing and wide loads |
Daily driving, off-road, light towing |
If you pull a camper or a gooseneck most weekends, start with real extended mirrors. Full stop.
But most owners don't tow that often. For a daily driver that hauls a dirt bike trailer a few times a year, wide-angle convex glass handles the everyday blind spot problem, and clip-on extensions can cover the occasional wide trailer. Plenty of owners run both.
And if your rig spends more time on trails than highways, generally speaking, convex glass in the factory housing is the cleaner choice. You get a wider view without a wider footprint. Our guide to the different types of truck side mirrors goes deeper on flat, convex, spotter, and towing styles if you're still weighing options.
We built the WOLFBOX Gear Wide-Angle Convex Side Mirrors for off-road use. They're designed for a wide range of vehicles, including trucks, Jeeps, and SUVs. Each set is a full replacement glass unit with a rigid backing plate that snaps into the factory mirror base. They aren't stick-on overlays.
Here's what you get:
A wider view. The convex glass expands your view by up to about 30% compared to factory glass. The WOLFBOX Gear Wide-Angle Convex Side Mirrors for the Ford F-150 and F-150 Raptor use R1200 curved glass.
Heat on every model. Defrost comes standard and connects to your OEM heating circuit.
Optional blue anti-glare glass. A nano-coated tint cuts glare from high beams behind you.
Blind spot monitoring depends on the fitment. Only some versions work with factory blind spot monitoring (BSM, which Ford calls BLIS). The F-150 and F-150 Raptor fitment comes in Heated, Heated + BSM, and Heated + Turn Signal + BSM versions. The Ford Bronco fitment and the previous-generation Toyota Tacoma and 4Runner fitment offer a Heated + BSM version, but their base heated versions don’t support it. Other fitments, including the Jeep Wrangler JL and Gladiator JT, come in a heated version only and don’t support BSM at all. So if your Jeep has factory blind spot monitoring, the mirrors won’t keep that feature working. And no version can add blind spot monitoring to a vehicle that didn’t come with it, so check the fitment notes for your vehicle before you order.
One note for F-150 owners: this fitment doesn't work on trucks with factory towing mirrors, the Raptor R, the Tremor, or the STX. Also, the electronic auto-dimming feature goes away with the swap, and the blue glass is the anti-glare alternative. Fitment notes vary by model year, so check the list for the specific truck you own.
Fitments go beyond Ford, too. There are versions for the Chevy Silverado 1500, 2500 HD, and 3500 HD, the Jeep Wrangler JL and Gladiator JT, the Ford Bronco, and the latest Toyota Tacoma. You can see every fitment in the WOLFBOX Gear side mirrors lineup.
Install is a DIY job for most owners. Pop the old glass out with a pry tool, connect the heater leads, and snap the new glass in.
New glass only helps if it's aimed right. Try this:
Sit in your normal driving position and set your inside rearview mirror first.
Lean your head toward the driver window. Adjust the left mirror until you can just barely see the side of your truck.
Lean toward the center of the cab. Adjust the right mirror the same way.
Sit back up. You shouldn't see much of your own truck now, and that's the point.
Test it. Watch a car pass you on the highway. It should leave the inside mirror and show up in the side mirror with little or no gap.
When towing, you'll likely need to aim the mirrors back in so you can track the trailer's sides and tires. That's normal.
For more on picking glass by vehicle and use, check out how to choose the right truck side view mirror.
Better visibility doesn't always mean bigger mirrors. For a lot of owners, smarter glass does the job. If you want a wider view without changing your factory mirror width, take a look at the WOLFBOX Gear Wide-Angle Convex Side Mirrors for your rig. Every order is backed by our Guaranteed Fit promise, so it fits your rig, or it's on us. Get out there and see more of the trail.
If your trailer is wider than your truck, you'll usually need them to see down its sides. Many states require a clear view of the road behind you while towing. Check your state's DMV rules for the exact requirement.
They're better for seeing more of the lanes beside you. Flat mirrors are better for judging distance, since they show objects at true size. Many drivers prefer convex glass for blind spots once they get used to it.
The curve squeezes a wider view into the same glass, so everything looks smaller. Your brain reads smaller as farther away. That's why federal rules require a warning line on convex passenger side mirrors.
Yes. Many tow mirrors already include a small convex spotter section, and some owners add clip-on extensions over convex glass when towing.
WOLFBOX Gear Wide-Angle Convex Side Mirrors are designed for off-road use and may not meet every FMVSS 111 requirement. Mirror rules can vary by state, so check your local regulations before using them on public roads.
Most installs take 10 to 30 minutes with a basic pry tool. The glass snaps onto the factory mirror base, and you connect the heater leads. No drilling or cutting is needed.
