$1,099.99
running boards
Power Running Boards
Unlock the full potential of your next-gen Ford with the ultimate Power Running Boards. Specifically tuned for the 2021-2027 F-150 and 2022-2027 Super Duty, our system deploys in 1.5s, providing seamless access while preserving your truck's advanced aerodynamics and iconic lines.
Key Features & Highlights:
- Arctic-Tested (-40°F): High-torque motor engineered to break through heavy ice and snow buildup. Reliable operation even in the harshest winter conditions across the North.
- Massive 660 lbs Capacity: Built from 6063-T5 aircraft-grade aluminum. Engineered for rock-solid support, handling heavy workloads and daily abuse with ease.
- IP67 Waterproof Motor: A fully sealed motor system built to survive deep mud, winter road salt, and high-pressure washes.
- High-Clearance Stealth Design: Retracts flush under the rocker panel for a clean, in-line look. For F-150 Lightning owners, this aerodynamic profile helps maintain maximum driving range.
- Integrated LED Lighting: Ambient LED lights illuminate the 6-inch anti-slip surface for improved visibility and confidence in low-light environments.
- Next-Gen Precision Fit: 100% bolt-on installation using Ford’s latest factory mounting points for a seamless, no-drill DIY setup.
- 5-Year Limited Warranty: Wolfbox backs its power steps with a 5-year limited replacement warranty, protecting against structural and workmanship defects. View More
Elevate Your Rig’s Potential:
No-nonsense power for those who demand excellence from their truck. Stop struggling, start stepping. Upgrade your Ford with Wolfbox Power Running Boards.
Fitment Power Running Boards
