Do you make power running boards fit 2014 ram 1500 crew cap. Have not been able to found to find any .
Power Running Boards for Ram 1500: What To Know Before Buying
Time to read 9 min
Time to read 9 min
Weight capacity, motor quality, construction material, and IP weather rating are the four specs that separate a board that lasts from one that doesn't.
Ram 1500 fitment varies by cab style, model year, and body generation, so verifying compatibility before ordering isn't optional.
Installation is typically bolt-on for the brackets, but wiring into the door trigger circuit adds time if you're not comfortable with basic automotive electrical work.
When fully retracted, quality power running boards recover meaningful ground clearance compared to fixed steps or nerf bars.
Walk up to a Ram 1500 equipped with power running boards, open the door, and a solid step extends out from under the rocker panel. Close the door and it tucks back up. No lifting, no folding, no manually deploying anything.
That automatic movement is what separates them from fixed side steps and nerf bars. They're electronically actuated, meaning a signal from the door sensor tells a motor to push the board out through a deployment cycle. Most quality units complete that motion in about one to two seconds.
Sound simple enough? It is, in concept. But here's where a lot of buyers get tripped up: not every power running board is built to the same standard, and not every set fits every Ram 1500 configuration. Before spending over a thousand dollars, there's a lot worth understanding.
The deployment mechanism uses a 12V DC motor connected to an actuator arm or a rack-and-pinion linkage. When a door opens, the door ajar signal from the Ram's body control module triggers the motor controller, which runs the board through its full extension. When all doors close, the controller reverses the cycle and the board retracts flush under the rocker panel.
Some kits tap directly into the Ram 1500's door wiring harness to read the OEM switch signal. Others use a plug-and-play controller that reads CAN bus data if your truck supports it. The door trigger method is more universally compatible across Ram model years and tends to be the more reliable long-term approach.
A well-built set deploys quickly and quietly. If product reviews mention grinding, slow movement, or hesitation during the cycle, that's typically a sign of an undersized motor or a low-quality actuator. On the Ram 1500, which has a fairly high rocker panel height compared to mid-size trucks, you want a board that fully extends in under two seconds. Cold weather can slow motor response slightly in poorly sealed units, which is worth keeping in mind if you're in the northern states or running high-altitude trails.
This is where most buyers make mistakes. They focus on aesthetics and gloss over the technical details that determine whether the boards hold up season after season.
Don't skip this one. Quality power running boards for the Ram 1500 should carry a minimum rated static load capacity of 300 to 400 pounds on the deployed step surface. If you're using the step to load gear into the bed or helping passengers who put real weight on it, you want the higher end of that range. Look for a specific weight rating from the manufacturer, not vague marketing language about "heavy-duty construction."
The motor is what everything else depends on. Brushless motors last significantly longer than brushed designs through thousands of deployment cycles. Linear actuators tend to be mechanically simpler than rack-and-pinion systems, with fewer components that can wear or fail. Sealed motor housings are non-negotiable for anyone who drives off-road or in wet conditions. An unsealed motor exposed to mud and water crossings won't last a full season.
Aluminum alloy is the standard choice for a reason. It handles temperature swings, resists corrosion, and adds less unsprung weight than steel. Some boards use steel for added rigidity under heavier loads, which is a reasonable tradeoff if you're in a heavier-use situation. Either way, look for powder-coated or anodized finishes. Raw or thin-coated aluminum sitting under a Ram's rocker panel through a Midwest winter of road salt will start showing wear fast.
This matters more than most people realize. An IP67 rating, defined under IEC 60529 by the International Electrotechnical Commission, means the motor and electrical components are protected against temporary water immersion up to about 3.3 feet deep for 30 minutes. IP68 goes further. If a product listing doesn't mention an IP rating for the motor and controller, that's worth noting. Electrical components without proper moisture protection don't survive long underneath a truck's rocker panel, especially in rain, snow, or water crossings.
The step surface itself should be wide enough to be genuinely useful and textured or grooved to prevent slipping. Wet boots, muddy boots, and work boots all need grip. On a Ram 1500 Crew Cab, you've got more door span to work with than a Quad Cab, so board length and step placement matter especially for rear passengers.
Not all power running boards for the Ram 1500 fit all Ram 1500 trucks. The Ram platform went through a full-generation change with the fifth-gen body, and the Ram 1500 Classic body continued in production as a separate model after that transition. Brackets and wiring harnesses designed for one generation often don't transfer to the other.
Cab configuration adds another layer. Crew Cab and Quad Cab variants have different door spacing, which affects where the mounting points land on the frame rail. Always match the product to your specific cab style, model year range, and body generation. Getting this wrong means brackets that don't align or step placement that's off relative to your door openings.
Bed length doesn't directly affect running board fitment since the boards mount to the frame and rocker panel, not the bed itself. But it often appears in product compatibility listings, so it's worth knowing where your truck falls.
Most power running board kits for the Ram 1500 are designed for bolt-on installation using existing frame mounting points. You're generally working with three things: frame brackets that attach to pre-drilled mounting points on the underside of the truck, a wiring harness that connects to the door trigger circuit, and a motor controller that manages the deployment cycle.
The physical bracket installation typically takes two to three hours with basic hand tools. Wiring is where people sometimes get stuck. Tapping into the door ajar circuit on the Ram 1500 requires finding the right wire in the door jamb area and connecting to it cleanly. If you've done basic automotive wiring before, it's straightforward. If not, having a shop handle the wiring while you do the bracket work is a perfectly reasonable split.
Quality fitment-specific kits don't require any cutting of the factory frame. That matters for anyone who doesn't want to compromise the truck's structure for an accessory.
The Society of Automotive Engineers publishes electrical connector and wiring standards relevant to automotive accessories like these, which is worth referencing if you're doing the wiring install yourself and want to understand best practices for connector protection and circuit protection.
For daily drivers where cab entry height is a real issue, yes. The Ram 1500 sits high enough that kids, shorter passengers, and anyone dealing with knee or hip issues genuinely benefit from a powered step. Fixed nerf bars help, but they don't retract. A step that tucks out of the way when you don't need it is a meaningfully different product.
For off-road use, the retraction feature is what makes these worth it. When the boards tuck up under the rocker panel, you recover several inches of clearance on each side. On rocky terrain in the Southwest or the Pacific Northwest where approach angles matter, a fixed step hanging below the frame is a liability. A retractable one isn't.
Not just for Ram trucks either. We build our WOLFBOX Gear power running boards for off-road use and they're compatible with a wide range of vehicles including trucks, Jeeps, and SUVs, so the same engineering that handles trail use on a Ram handles it elsewhere in your fleet.
Retraction recovers ground clearance that fixed steps permanently sacrifice
Clean, integrated look when retracted compared to permanent nerf bars
Step surface stays protected when tucked, reducing trail damage exposure
Accessible for a wider range of passengers regardless of height or mobility
More components mean more potential failure points over a high-mileage lifespan
Wiring adds install complexity for DIY buyers unfamiliar with automotive electrical work
Motor performance can drop in extreme cold if the unit isn't properly weather-sealed
If you're ready to look at specific options, browse our WOLFBOX Gear power running boards for fitment details by vehicle. Every product includes fitment specs by model year and cab style so you can confirm compatibility before ordering. We also offer a retractable bed step if you need rear bed access built into your setup.
Questions before you buy? Our team is available at +1 888-432-7508 (Monday through Friday, 9AM to 7PM) or at gears@wolfbox.com.
Power running boards are electrically actuated side steps that extend automatically when a truck door opens and retract when it closes. They're mounted to the frame rails under the rocker panel and use a 12V DC motor to drive the deployment cycle.
No. Fitment varies by model year, body generation (fifth-gen vs. Ram 1500 Classic), and cab style (Crew Cab vs. Quad Cab). Always verify compatibility by your specific year, cab configuration, and body style before purchasing.
When retracted, quality boards sit flush near the rocker panel and add minimal height compared to the vehicle's factory clearance. The advantage over fixed steps is that the boards tuck away when you don't need them, recovering clearance on the trail.
In most cases, yes. Bracket installation is straightforward with basic hand tools and usually takes two to three hours. The wiring requires tapping into the door ajar circuit, which is manageable with basic automotive electrical experience. If you're not comfortable with that part, a shop can handle the wiring while you do the bracket work.
Look for a rated static load capacity of at least 300 to 400 pounds on the deployed step. Higher is better if you'll be regularly using the step to access the bed or if heavier passengers depend on it for cab entry.
Most do fine, but motor response can slow in extreme cold below around negative 4°F if the unit isn't adequately weather-sealed. Look for boards with IP67 or IP68 rated motor housings and sealed electrical connectors if you're in a northern state or running winter trails.
It depends on what you're optimizing for. Nerf bars are simpler, less expensive, and have no electrical components to maintain. Power running boards cost more but give you automatic deployment, retractable ground clearance when off-road, and a cleaner look when the step is tucked. For daily drivers with mixed on-road and trail use, most owners find the tradeoff worthwhile.
Comments
