How are you using the obd2 port when Amp has the patent on that?
AMP Research Power Running Boards vs. WOLFBOX Gear: Which One Actually Wins?
Time to read 9 min
Time to read 9 min
WOLFBOX Gear power running boards carry a 660 lb load capacity and an IP67 waterproof rating, both of which exceed what the standard AMP Research PowerStep offers.
Both systems use Plug-N-Play wiring for most installations, and both are sold in vehicle-specific configurations.
WOLFBOX boards include anti-pinch protection as a standard feature. AMP Research's pinch-proof technology varies by model.
The XTreme model from AMP Research uses dual motors and is designed specifically for extreme off-road and winter environments. WOLFBOX boards cover the needs of most daily-driver and mild-trail truck owners with stronger baseline specs.
If you're shopping for power running boards, AMP Research is probably the first name you've come across. They've been in this space for a long time, and their name shows up constantly in forums and search results. But name recognition isn't the same thing as the best option for your rig.
So what's actually different between AMP Research power running boards and WOLFBOX Gear's lineup? Let's break it down.
Power running boards are motor-driven side steps that automatically deploy when a door opens and retract when it closes. Unlike a fixed running board, they tuck up near the rocker panel while you're driving. That keeps them protected from rocks and brush on the trail, reduces drag on the road, and gives your truck a cleaner profile when the boards aren't in use.
For lifted trucks, families with shorter passengers, or anyone who's regularly loading gear in and out of the cab, these boards make a real difference on a daily basis. A static step mounted at the wrong height is almost as bad as no step at all.
AMP Research holds the original patents on the automatic power step design. Their PowerStep line has been around for years and has gone through multiple generations of refinement.
The standard PowerStep is the entry-level option. It runs a single motor per side, fits a wide range of trucks, and represents what most people picture when they search "AMP Research power running boards." The step surface is 6 inches wide and runs cab-length, with integrated LED lighting.
The PowerStep XL drops 4 inches lower than the standard model at deployment. It's built specifically for lifted trucks where the added drop bridges a gap that a standard board won't reach comfortably.
The PowerStep XTreme steps things up for serious off-road and winter use. It runs dual motors per side, which give it more torque to push through ice, mud, and debris buildup that can slow or bind a single-motor system. It also requires some drilling during installation, which is different from the other models in the lineup.
The PowerStep Vision is the most tech-forward option. It adds Bluetooth app control through the AMP Research SmartSeries app, letting you control and monitor the boards from your phone. LED lighting is included.
Each model is vehicle-specific. You're buying a kit built for your exact year, make, and model rather than a universal setup.
AMP Research uses die-cast aluminum alloy construction across the lineup with an anodized, PTFE-coated finish they describe as military-spec. The pivot points use self-lubricating composite bushings, which keep maintenance needs low over time. Load capacity is 600 lbs per side across all PowerStep variants.
The standard PowerStep and most variants are weather-resistant and tested in extreme temperature ranges. AMP Research doesn't publish a standardized IP waterproof rating on most models, but they do reference real-world durability testing, including 1,000-hour salt spray tests on the XTreme.
The warranty across the PowerStep line is 5 years or 60,000 miles, covering manufacturing defects under normal use.
We didn't build our power running boards to match what was already out there. We built them to actually improve on it.
Our boards are made from rust-proof, high-strength aluminum with a slip-resistant step surface. They're designed to hold up from salt-covered Midwest roads in January to muddy desert trails in the Southwest.
The load capacity is 660 lbs per side. That's 60 lbs more per side than AMP Research's standard PowerStep. But the real story isn't about hauling objects. It's about structural integrity and real-world dependability. A higher load rating means more stable, confident entry and exit for drivers and passengers of all sizes. It means the boards hold firm under the kind of repeated daily stress that wears cheaper hardware down over time. And out on the trail, where you're stepping up and off with boots caked in mud and a pack on your back, that structural margin is what keeps the boards solid and reliable for the long haul.
Our boards carry an IP67 waterproof rating. That designation comes from the International Electrotechnical Commission and means the motors and electrical components are certified dust-tight and rated for submersion up to 1 meter for 30 minutes. It's not a marketing claim. It's a third-party verified rating relevant to river crossings, heavy rain, pressure washing, and anything else your truck goes through out there.
Anti-pinch protection is standard on every WOLFBOX board. If the step senses resistance while closing, it stops and reverses. That's important if you've got dogs, kids, or gear near the boards during a cycle.
Wiring is Plug-N-Play on supported vehicles. No splicing, no cutting into factory wiring. Each side operates independently based on which door opens, so the driver's board doesn't fire when a passenger gets out. LED lighting activates automatically at night.
No drilling required. The boards mount with a 100% bolt-on design to existing frame points on your truck.
We back every set with a 5-year warranty and a support team you can actually reach. Browse our full selection of WOLFBOX Gear power running boards and filter by your vehicle.
WOLFBOX Gear |
AMP Research PowerStep |
Deployment |
Automatic, door-triggered |
Load Capacity |
660 lbs per side |
600 lbs per side |
Waterproof Rating |
IP67 certified |
All-weather tested, no published IP rating |
Anti-Pinch Protection |
Standard on all models |
Varies by model (not standard on all) |
LED Lighting |
Included on most models |
Wiring Method |
Plug-N-Play, no splicing |
Plug-N-Play on most models |
Drilling Required |
No |
No on most models, yes on XTreme |
Warranty |
5-year limited |
5-year/60,000-mile limited |
Price Range |
$1,099.99 |
$1,399.99 to $2,299.99 (varies by model and vehicle) |
Best For |
Daily use, all-weather, heavy haulers, families |
Lifted trucks (XL), extreme off-road (XTreme), app connectivity (Vision) |
Pros:
Highest load rating in this comparison at 660 lbs per side
IP67 waterproof rating from a verified international standard
Anti-pinch protection included across the entire lineup
LED lighting standard, no upcharge or model tier required
No-drill installation on all supported vehicles
5-year warranty backed by accessible customer support
Cons:
Newer brand with a shorter history than AMP Research
Fitment coverage focuses on recent model years; older trucks may not be supported yet
Pros:
Multiple purpose-built model variants, including lifted-truck and extreme-climate options
Self-lubricating bushings across the lineup reduce maintenance over time
Bluetooth app connectivity available on the Vision model
Long track record in the category
Cons:
Load capacity maxes at 600 lbs per side
No published IP waterproof rating on most models
XTreme installation requires some drilling and wire splicing
Features like anti-pinch aren't consistent across all model tiers
Both systems are designed for DIY installation with vehicle-specific hardware kits. That means the brackets, harness, and mounting hardware are already sized for your truck. You're not fabricating or adapting anything.
WOLFBOX Gear board installs typically run about two hours. The wiring taps into the door signal circuit without cutting or splicing factory wires. The boards bolt directly to existing frame mounting points.
AMP Research installs follow a similar process on the standard PowerStep and XL. The OBD-II Plug-N-Play option on compatible trucks is clean and keeps the install simple. The XTreme is a different story. It requires drilling and wire splicing, which AMP Research acknowledges in their documentation. If you're not comfortable with that, professional installation makes sense for that specific model.
The SAE sets automotive component testing standards that products like these are engineered around, and both systems are built to fit within factory vehicle electrical parameters when installed correctly. A basic socket set and a few hours is all most installs need for the no-drill options.
Not sure which direction to go? Here's the honest answer based on what you actually need.
If you've got a significantly lifted truck and need that extra deployment depth, AMP Research's PowerStep XL was designed for that use case specifically. If you run genuine extreme off-road through deep snow or mud and want dual-motor insurance, the XTreme was made for those conditions. If app connectivity matters to you, the Vision model offers that.
For most truck owners on a stock or mildly lifted F-150, Silverado, Tundra, or Ram, WOLFBOX Gear power running boards are the stronger all-around option. Higher load capacity. Certified IP67 protection. Anti-pinch standard. LED lights included on every board. No drilling needed. You're not trading anything away to get there.
We built these boards for real truck owners who want gear that works without question, whether you're at a job site in the Texas heat or on a logging road outside Portland in November.
The most significant spec differences are load capacity and waterproof rating. WOLFBOX Gear boards are rated at 660 lbs per side with an IP67 waterproof certification, while AMP Research's standard PowerStep is rated at 600 lbs per side and doesn't publish an equivalent IP rating. AMP Research offers more model variants, including the XL for lifted trucks and the XTreme for extreme off-road conditions.
AMP Research's PowerStep line is rated at 600 lbs per side across all model variants, including the XL, XTreme, and Vision.
IP67 is a protection rating defined by the International Electrotechnical Commission. It means the component is fully sealed against dust and protected against submersion in up to 1 meter of water for up to 30 minutes. On power running boards, this applies to the motors and electrical connectors, which are the most vulnerable parts when you're driving through water, mud, or hosing down the undercarriage.
Yes. The XTreme model installation involves drilling and wire splicing, which AMP Research documents in their install guides. AMP Research recommends professional installation for the XTreme. Their standard PowerStep and XL models generally don't require drilling for most vehicle applications.
No. WOLFBOX Gear power running boards use a 100% bolt-on design with no drilling required. Wiring connects without cutting or splicing factory wires. Most installs are completed in about two hours with basic hand tools.
It depends on the lift height. For stock and mildly modified trucks, standard power running boards work well. For significantly lifted setups, AMP Research's PowerStep XL is purpose-built to deploy 4 inches lower than the standard model to account for the added height.
When retracted, power running boards tuck up under the rocker panel, which restores most of your stock ground clearance. That's one of the main advantages over fixed running boards, which hang at a fixed height whether you're on pavement or off it.
Comments
I have a 2014 f150 crew cab, will your step fit
Plan on putting a 6 inch lift on my 2019 Ram rebel will steps be to high
