Tailgate Ladder vs. Retractable Truck Bed Step Ladder: Which One's Right for You?
Published on
Time to read 9 min
Tailgate ladders mount directly to the tailgate and offer multi-rung access, making them a strong option for lifted trucks or anyone who needs maximum stepping height.
Retractable bed steps tuck under the rear bumper when not in use, keeping your ground clearance clean and your truck's profile tight.
Installation complexity varies: most retractable bed steps are bolt-on and require no drilling, while tailgate ladders often involve drilling into the tailgate itself.
Ground clearance matters off-road. A retractable step that folds flush protects your approach angle in ways a fixed tailgate ladder can't.
The right choice comes down to how you use your rig, how often you access the bed, and how much you care about a clean look on the trail or the road.
Here's a question we hear a lot: "Do I need a tailgate ladder or a retractable bed step?"
It sounds simple. But once you start comparing them side by side, the differences get real specific, real fast. We're talking about ground clearance, install methods, bed access when the tailgate's closed, and what happens when you're parked on a slope in the Moab heat trying to grab your recovery gear.
Both options solve the same basic problem: truck beds are tall, and climbing in and out without a step wears you down fast. But they solve it in very different ways. Let's get into it.
Tailgate ladders attach directly to the tailgate itself, usually via bolts or self-tapping screws drilled into the tailgate skin. When you drop the tailgate, the ladder hangs down and gives you two or more rungs to step on as you climb up. Most are made from aluminum or steel, fold flat against the tailgate when not in use, and include some form of non-slip tread on each rung.
Retractable bed steps work differently. They mount to the frame or existing bolt points beneath the rear bumper and swing down when you need them, then tuck back up flush when you don't. Some deploy with a foot kick. Others drop automatically when you lower the tailgate. The WOLFBOX Gear Retractable Bed Step is a bolt-on design that uses your vehicle's factory mounting holes, so there's no drilling required on most modern trucks.
So right away, you've got two fundamentally different deployment methods, two different mounting approaches, and two different outcomes when it comes to things like clearance and bed access.
Ease of Access: Getting Into the Bed
This is usually the first thing people think about, and it's where the two designs differ the most.
Tailgate ladders give you multiple rungs to work with. If you've got a significantly lifted truck running 35s or 37s, or if your rear bumper sits 30-plus inches off the ground, that multi-rung setup genuinely helps. You're essentially climbing a small ladder rather than taking a big single step. For anyone with knee issues or shorter legs, that ladder approach can feel a lot safer.
But here's the catch. You have to drop the tailgate to use most tailgate ladders. The ladder lives on the tailgate face, so it's unavailable when the tailgate is closed. That's a real limitation if you're making frequent trips to grab tools or gear without wanting to drop and re-latch the whole tailgate every time.
Retractable bed steps solve that. They mount at the rear bumper corner, completely independent of the tailgate. The bed is open for business whether your tailgate is up, down, or even locked. Deploy the step, step up, reach in, step down, step retracts. That's the whole workflow. For tradespeople and anyone who accesses their bed dozens of times a day, that independence from the tailgate is a genuinely useful feature.
The WOLFBOX Gear Retractable Bed Step drops the step position down approximately 5 inches from the bumper level, which makes that first step up significantly easier without needing multiple rungs for most stock and mildly lifted trucks.
Ground Clearance and Off-Road Impact
This is where retractable steps have a clear edge. When stowed, a well-designed retractable step tucks under the bumper and stays there. It doesn't hang below your frame. It doesn't add anything to your departure angle. You can back up to a rock ledge, drag through brush, or crawl a technical line without worrying about the step catching something.
Fixed tailgate ladders? It depends on the design, but most do add some profile to the tailgate that hangs below the bed floor level when the tailgate is down. And if you're off-road with your tailgate dropped (which plenty of overlanders do for ventilation or loading), that ladder is dangling there.
That said, some tailgate ladders fold flat enough that the concern is minimal on moderate trails. If you're running easy fire roads and forest paths in the Pacific Northwest, it might never matter. But if you're doing technical four-wheeling in the Southwest or crawling rocky terrain in Colorado, departure angle is something you protect actively. A retractable step that fully retracts wins that category.
Installation: How Hard Is It to Mount Each One?
Most tailgate ladders install in one of two ways. Simpler designs use safety straps and adhesive-backed bump pads that require no drilling at all, but those tend to be less secure and prone to shifting. More robust designs bolt directly through the tailgate skin, which means drilling. If you're handy with a drill and comfortable making permanent modifications to your tailgate, it's manageable. If not, it's a bigger commitment than it first appears.
Retractable bed steps generally install easier, especially vehicle-specific designs like the WOLFBOX Gear Retractable Bed Step. According to WOLFBOX Gear's installation documentation, most installations are completed in approximately 30 minutes using basic hand tools, and no drilling is required because the step uses your truck's existing factory mounting holes beneath the rear bumper. That's a bolt-on installation that doesn't alter your vehicle's structure.
There's also the question of compatibility. Tailgate ladders are often marketed as "universal fit," but universal doesn't always mean easy. Tailgates vary significantly in height, and some ladder designs aren't compatible with trucks that have tailgates shorter than 21 inches, or with trucks running a tonneau cover. Vehicle-specific retractable steps eliminate most of those headaches because they're engineered for your exact make and model.
Durability and Weather Performance
Both types of products can be built well or built cheap. That's honest. The materials and construction quality vary widely across the market.
Generally speaking, tailgate ladders made from aluminum are lighter and resist corrosion well. Steel versions are heavier but can be more rigid. The concern with tailgate ladders is the mounting hardware and hinge points. Those are the spots that take stress repeatedly, and low-quality pivot designs can develop slop over time. Powder-coat finishes hold up fine in most climates but won't survive heavy coastal salt exposure forever without maintenance.
Retractable bed steps with die-cast aluminum construction, like the WOLFBOX Gear Retractable Bed Step, handle that durability demand well. Die-cast aluminum gives you corrosion resistance, good rigidity, and a relatively low weight penalty. The spring-loaded or latch mechanisms that keep the step up need to hold up to repeated deployment cycles. When they're engineered right, they do. When they're not, you end up with a step that droops or won't lock.
Neither design requires significant ongoing maintenance in normal use. Rinse the mud off, check the hardware seasonally, and both should hold up for years.
Comparison Table
Tailgate Ladder
Deployment
Drop tailgate, ladder hangs down
Foot-kick or manual deploy, independent of tailgate
Ground clearance impact
Hangs lower when tailgate is open
Tucks flush under bumper when retracted
Moderate to high (often requires drilling)
Low (typically bolt-on, no drilling)
Price range
$50 to $200+
$150 to $250+
Best for
Lifted trucks, those needing multi-rung access
Frequent bed access, off-road clearance, clean install
Who Should Pick a Tailgate Ladder?
If your truck is significantly lifted and that first step up is genuinely a challenge even with a single-step solution, a tailgate ladder gives you the multi-rung height to work with. It's also a reasonable option if you primarily access the bed when the tailgate is already down (like hauling a load or working out of the bed on a job site), so the tailgate dependency doesn't bother you.
Budget is another factor. You can find a functional tailgate ladder for under $100. If you just need basic access improvement and aren't worried about off-road performance or a clean retracted profile, a simple ladder gets the job done.
Who Should Pick a Retractable Bed Step?
If you access your truck bed frequently throughout the day, want a clean look when the step isn't in use, care about preserving rear ground clearance for off-road use, or don't want to drill into your tailgate, a retractable bed step is the better choice for most truck and SUV owners.
The WOLFBOX Gear Retractable Bed Step fits the Ford F-150, F-150 Lightning, Chevy Silverado, and other popular platforms with a vehicle-specific fit. It's rated to 330 lbs, installs without drilling in roughly 30 minutes, and tucks fully out of the way when you don't need it. For drivers who use their rigs for daily driving and weekend off-road use, that kind of dual-purpose functionality matters.
Ready to Step Up?
If a retractable bed step sounds like the right fit for your truck, Jeep, or SUV, browse the full selection at WOLFBOX Gear's truck steps collection. Every option is vehicle-specific, backed by a guaranteed fit policy, and built for real-world use on and off the road.
What's the difference between a tailgate ladder and a retractable truck bed step?
A tailgate ladder mounts to the tailgate itself and hangs down when the tailgate is lowered, giving you multiple rungs to climb. A retractable truck bed step mounts under the rear bumper independently of the tailgate, deploys on demand, and tucks away flush when not in use. The main practical differences are deployment method, installation approach, and ground clearance impact.
Do I have to drop my tailgate to use a retractable bed step?
No. Retractable bed steps mount to the frame or factory bumper mounting points, so they're completely independent of the tailgate. You can access the step with the tailgate up, down, or locked, which makes them more versatile for frequent bed access.
Will a tailgate ladder work with a tonneau cover?
It depends on the ladder design. Some tailgate ladders are not compatible with tonneau covers, especially covers that extend over or near the tailgate. Always check the product's fitment notes before purchasing if you're running a bed cover.
Does a retractable bed step affect ground clearance?
When properly retracted, a quality retractable bed step tucks under the rear bumper and doesn't significantly affect rear departure angle. Fixed tailgate ladders, when the tailgate is lowered, can hang below the bed floor and potentially impact clearance on steep descents. For off-road use, a retractable step is the better choice for preserving clearance.
How much weight can a retractable bed step hold?
Weight capacity varies by product. The WOLFBOX Gear Retractable Bed Step is rated to support up to 330 lbs. Most quality retractable steps in this category are rated between 300 and 350 lbs, which is adequate for the vast majority of users. For reference, some heavy-duty commercial side-mount steps are rated higher, up to 500 lbs, for work truck applications.
Is drilling required to install a retractable bed step?
Not necessarily. Vehicle-specific retractable bed steps, like the WOLFBOX Gear Retractable Bed Step, use existing factory mounting holes beneath the rear bumper, so no drilling is required on most compatible trucks. Universal-fit or tailgate-mounted ladders more frequently require drilling to achieve a secure mount.
What truck models are compatible with the WOLFBOX Gear Retractable Bed Step?
The WOLFBOX Gear Retractable Bed Step is available in vehicle-specific fitments for popular trucks and SUVs including the Ford F-150, Ford F-150 Lightning, and Chevrolet Silverado, among others. Check thetruck steps collection and select your year, make, and model to confirm fitment for your specific vehicle.
i notice you don’t offer anything for the 2023 ford ranger, is it that much difference between the 2023 and the 2024?
thanks
and are you going to make a retractable step for the ranger?
Scroll to the top of the page
Choosing a selection results in a full page refresh.
