ford_power_running_boards_factory-vs-wolfbox-gear-aftermarket-options
Ford Power Running Boards: Factory vs Aftermarket Options
Published on
Time to read 9 min
  • Factory Ford power running boards are usually locked to upper trims like Platinum, King Ranch, and Limited, so many F-250 and F-150 owners never get the option at the dealership.
  • Aftermarket power running boards, like WOLFBOX Gear power running boards, can be added to nearly any trim after the truck is already yours.
  • Retrofitting factory power steps after purchase often runs $1,400 to $2,000 once parts and dealer labor are added in, while aftermarket kits list for less and install without cutting a single wire.
  • Both options use the truck's factory door signal to trigger deployment, but installation complexity and available warranty coverage differ quite a bit.
  • Weight capacity, waterproofing, and cold weather performance are rarely published for factory boards. Reputable aftermarket brands publish these numbers so you know exactly what you're getting.
Every Ford Super Duty or F-150 owner hits this fork in the road eventually. Do you go factory, or do you go aftermarket?
It's not a simple question. Ford's own power running boards look clean and match the paint, but they're not sold as a standalone accessory on every trim. Aftermarket brands fill that gap, and some of them, WOLFBOX Gear included, build kits specifically for the Ford lineup. This guide breaks the decision down by the things that actually matter: cost, speed, durability, installation, and fitment.
Cost of Ford Power Running Boards: Factory vs Aftermarket
Money is usually where this decision starts.
If you order a Ford truck with power running boards as a factory option on a qualifying trim, the added cost is often in the $400 to $500 range on the window sticker. Sounds reasonable. The catch is that this price only applies when the boards are ordered new, on a trim that supports them.
Miss that window and things get expensive fast. Ford owners who want factory-style power steps added after the fact typically need the dealer parts department to source the correct running board assembly, wiring harness, and control module, then pay for installation. Forum reports from Super Duty owners doing this exact retrofit put the total cost around $1,400 to $1,500 including parts.
Aftermarket power running boards skip that whole process. WOLFBOX Gear power running boards for the F-250, F-350, F-450, and F-550 (20-22) list for $1,099.99, and pricing varies depending on your specific truck and cab configuration. You're not paying dealer labor rates, and you're not restricted to a specific trim level.
One thing worth noting: neither option is cheap. This isn't a budget accessory category. But the aftermarket route generally gets you a comparable feature set without the trim lock-in that factory options come with.
Deployment Speed and Technology
Both factory and aftermarket power running boards work the same basic way, and we've broken down the full mechanics of how power running boards deploy and retract in more detail elsewhere. In short, a sensor reads the door signal, a control module fires an electric motor, and a linear actuator pushes the step out.
Where they differ is in how that signal gets read and how fast the whole thing happens.
Factory Ford systems typically tap into the vehicle's OBD-II port and truck-specific wiring to read door status. It's a clean, integrated approach since the automaker controls the entire electrical architecture from the start.
Aftermarket systems have had to get creative here. WOLFBOX Gear uses CAN bus technology to read door signals directly from the factory wiring, which means no splicing and no unreliable magnetic switches. Deployment happens in about 1.5 seconds on Ford applications, which is on the faster end for this category.
Sound familiar if you've ever waited on a slow-deploying step while holding a bag of groceries? That's the gap this technology is meant to close.
One more note on the lighting side. Any auxiliary lamp added to a vehicle, including the LED strip built into a power running board, falls under NHTSA's Federal Motor Vehicle Safety Standard No. 108, which governs lamps and reflective devices. Reputable manufacturers design integrated step lighting to stay compliant with that standard rather than treating it as an afterthought.
Durability and Weather Resistance
This is where documentation matters. A lot.
Ford doesn't publish detailed environmental ratings for its factory power running boards, at least not in consumer-facing spec sheets. Owners report solid real-world reliability, but there's no published IP rating or temperature range to point to for comparison.
WOLFBOX Gear power running boards, on the other hand, are built from 6063-T5 aircraft-grade aluminum with an IP67-rated motor, meaning the motor is sealed against dust and can handle temporary submersion. The whole system is rated to operate from -40°F up to 176°F, and it's been ice tested in real winter conditions. For anyone running a Super Duty through Midwest snow or Pacific Northwest logging roads, that kind of documented range matters more than a marketing photo.
Generally speaking, published specs give you something concrete to hold a product to. Vague claims don't.
Weight Capacity and Ground Clearance
Weight capacity is another area where factory documentation tends to be thin.
WOLFBOX Gear power running boards are rated to support 660 lbs per side, built on a die-cast aluminum hinge system designed to handle two adults standing at once. When retracted, the boards tuck flush against the rocker panel, preserving ground clearance for trail use. Deployed, they drop 13 to 15 inches below the door depending on the truck.
Ford's factory boards are engineered to a similar general concept, drop down for entry, retract for clearance, but the brand doesn't typically list a specific per-side weight rating for consumer reference. If load capacity matters to you (and for a family hauling gear in and out of a Super Duty, it should), that's a question worth asking before you buy either option.
Installation: Dealer Work vs DIY
This dimension might be the biggest practical difference between the two.
Factory power running boards, when ordered with a new truck, are installed at the factory or by the dealer before delivery. Adding them later is possible but involved. It generally requires sourcing the correct bracket kit, running board assembly, and control module, then having a dealer or experienced technician install and, in some cases, code the vehicle's onboard computer to recognize the new hardware. This isn't a Saturday afternoon project for most owners.
Aftermarket kits are built with the opposite goal in mind. WOLFBOX Gear power running boards use a 100% bolt-on design that relies on the truck's existing factory mounting points. No drilling. The wiring harness plugs into existing connectors instead of requiring you to splice into factory electronics, and Ford owners installing the kit themselves report finishing the job in about 1 to 2 hours with basic tools.
That's a meaningful difference if you're the kind of owner who'd rather spend a Saturday in the garage than schedule a dealer appointment three weeks out.
Fitment and Trim Availability
Here's the part that trips a lot of Super Duty and F-150 shoppers up.
Factory power running boards aren't available across the entire trim lineup. On the Super Duty, they've historically been tied to higher trims like Lariat and above, with base and mid-tier trims like XL and XLT left out entirely. If you ordered your truck without checking that specific box, you're stuck without the factory version.
Aftermarket manufacturers build to the vehicle's cab and body style, not its trim badge. WOLFBOX Gear offers dedicated fitment for the F-250, F-350, F-450, and F-550 Crew Cab (20-22), a separate kit for the F-150 (15-20) and Super Duty (17-19), another built for the F-150, F-150 Lightning, and Super Duty (21-26), and a Bronco-specific version for the 2021-2026 four-door. So whether you're driving an XL work truck or a Platinum, the aftermarket route doesn't care what badge is on the tailgate.
Not sure which version fits your specific truck? Checking your exact model year and cab configuration against the fitment chart before ordering saves a return down the road.
Warranty and Support
A factory-installed accessory ordered with a new Ford is generally covered under Ford's New Vehicle Limited Warranty for the duration of that coverage period. That's a real advantage if something goes wrong early and you're already at the dealership for other service.
Aftermarket coverage depends entirely on the manufacturer. WOLFBOX Gear backs its power running boards with a 5-year limited warranty against structural and workmanship defects, which extends well past most new vehicle bumper-to-bumper terms. It won't cover you for unrelated Ford electrical issues, but for the step system itself, it's a longer runway than what most owners get once factory coverage expires. If you're weighing power boards against a fixed step altogether, our breakdown of power running boards versus traditional side steps covers that decision too.
Whichever direction you go, keep the paperwork. You'll want it if you ever need to make a claim.
Ford Power Running Boards Comparison Table
Factory (Ford)
Aftermarket (WOLFBOX Gear)
Deployment
OBD-II based, dealer or factory installed
CAN bus signal, 1.5 second deploy
Trim availability
Limited to select higher trims
Available across most cab and body styles
Weight capacity
Not typically published
660 lbs per side
Weather rating
IP67 motor, -40°F to 176°F
Dealer or specialty technician recommended
No-drill DIY bolt-on, roughly 1 to 2 hours
Price range
$400-500 as new-order option; $1,400+ to retrofit
Starting around $1,099.99, varies by vehicle
Warranty
Ford New Vehicle Limited Warranty
Which One Should You Choose?
There's no universal right answer here. If you're ordering a new Super Duty or F-150 on a trim that already includes power running boards, taking the factory option keeps everything under one warranty and one invoice. Simple as that.
But if your truck didn't come with them, or you're on a trim Ford doesn't offer them on, the math shifts fast. Retrofitting a factory system is expensive and involved. An aftermarket kit built specifically for your Ford, with published specs you can actually verify, tends to be the more practical route for most owners in that situation.
We'd also point out that power running boards aren't exclusive to one truck brand in the aftermarket space. WOLFBOX Gear builds fitments across the Ford, Chevy, GMC, Ram, and Toyota lineups, which is part of why the fitment options tend to be broader than what a single automaker offers on one model line.
Upgrade Your Ford With WOLFBOX Gear
If you're ready to add power steps to your Ford without waiting on a dealer parts order, take a look at the full WOLFBOX Gear power running boards collection. Every kit is built for a specific fitment, backed by a 5-year limited warranty, and designed to bolt on without drilling into your truck. Find the version built for your Super Duty, F-150, or Bronco, and get back to loading up without the extra step.
Do all Ford trucks come with power running boards from the factory?
No. Factory power running boards are typically offered as an option only on select higher trims, such as Platinum, King Ranch, and Limited. Base and mid-tier trims like XL and XLT usually don't have the option available at all.
Can I add factory power running boards to a Ford that didn't come with them?
In most cases, yes, but it requires sourcing the correct running board assembly, wiring harness, and control module through a dealer, plus installation labor. Total cost typically lands well above what the same option costs when ordered new.
Are aftermarket power running boards as durable as factory ones?
It depends on the brand. Reputable aftermarket manufacturers publish specific weight capacity and weather resistance ratings, which gives you something concrete to compare. Ford generally doesn't publish those same figures for its factory boards, so a direct comparison isn't always possible.
How much do Ford power running boards cost?
Factory boards run roughly $400 to $500 as a new-order option, or $1,400 or more to retrofit later. Aftermarket kits like WOLFBOX Gear power running boards start around $1,099.99, with pricing varying by specific truck and configuration.
Do aftermarket power running boards affect my Ford's factory warranty?
Adding an aftermarket accessory that's installed correctly and doesn't damage factory wiring generally doesn't void your vehicle's overall warranty. Under the Magnuson-Moss Warranty Act (15 U.S.C. § 2302), a dealer can't deny coverage just because an aftermarket part is present. They'd have to show that specific part caused the failure. The running boards themselves would be covered under the aftermarket manufacturer's own warranty, not Ford's.
How long does it take to install aftermarket power running boards?
Most owners installing a no-drill bolt-on kit report finishing in about 1 to 2 hours with basic hand tools, working alone or with help from a second person.
What's the weight capacity of power running boards?
It varies by brand and model. WOLFBOX Gear power running boards carry a 660 lb per-side rating. Factory Ford boards don't typically list a specific published figure, so it's worth asking your dealer directly if capacity matters for your use case.
Comments
99 f350
Steven
