For the motorized side foot rails, what is the max load (lbs) of a person stepping on it, thx
Should Truck Running Boards Be Installed at an Angle
Time to read 12 min
Time to read 12 min
You may have crouched down next to your truck. That's when it comes to mind: should truck running boards be installed at an angle, or is mine just broken? It's one of those things you don't notice until one day you do, and then you can't unsee it. From a practical standpoint: a slight tilt on a single-motor running board is usually normal. It barely indicates anything wrong. [1] [2] But "usually normal" isn't the same as "always normal" for trucks. This guide explains why that tilt takes place in the first place. We'll walk you through how to tell normal from a real problem in under a minute, and what to do if yours actually needs a fix.
The immediate answer: No. You do not need to install running boards at an angle on purpose. A slight inward slope toward the truck body is, in fact, an intentional design feature. Power running boards are designed with a built-in 4 to 5 degree inward tilt that fits natural body posture, improves anti-slip grip, helps drain water and debris, and leaves clearance for the chassis and linkage. The slope is engineered in, not installed in. You don't set it up intentionally. What actually matters is installing the board exactly according to the manufacturer's vehicle-specific mounting design. It has nothing to do with choosing a specific angle. [1] [3] That distinction trips people up because it sounds contradictory at first. The board isn't supposed to be angled, but a slight angle is fine anyway. The resolution? Your installation instructions never tell you to tilt the board. Bolt it up level, following the mounting points the manufacturer defines for your specific truck. The brackets are designed to mount to the truck frame using factory-existing holes with bolts or clamp nuts — no drilling into the frame is required. Once the board is bolted level, the 4 to 5 degree inward slope you see after deployment is part of the design, not a sign of an installation mistake.
Single-motor running boards may look more tilted than expected because the 4 to 5 degree inward slope is part of the design, not a defect. Once you understand the four reasons behind the slope, the lean stops looking like a quirk and starts looking like an engineering choice.
The factory designs the board with a slight 4 to 5 degree inward tilt for four practical reasons. None of them are accidental, and all of them are visible once you know what to look for:
On top of the built-in 4 to 5 degree slope, a single-motor system can add a small additional front-to-rear height difference at deployment. The motor sits on the front bracket and drives both ends of the board through a connecting rod, so the rear end receives slightly reduced torque after passing through each linkage junction and may end up about 1 to 2 cm lower than the front. That small extra drop is mechanical, but the 4 to 5 degree slope itself is the dominant factor and is by design. The inward slope is not unique to one brand, either. Owners on Ford enthusiast forums have compared notes on factory-installed running boards angling down in the same way. Many noticed it from the very first day of ownership, which lines up with the slope being a deliberate design feature rather than something caused by wear or a loose bracket. [1] [2]
You can tell normal running board tilt from an original defect in about 60 seconds using four simple checks. If all four land in the 'Normal ' column, your board is fine even with a slight lean. If even one check falls into the 'Defect' column, treat it as a real problem and move on to the fixes.
Measure the front-to-rear height difference of the deployed board with a tape measure or ruler. Power running boards are intentionally designed with a 4 to 5 degree inward slope toward the vehicle body, so a 1 to 2 cm front-to-rear height difference is within the engineered normal range. Anything beyond 3 cm, especially when visually obvious or accompanied by noise, points to a real issue.
Listen closely during a full deploy-and-retract cycle. Smooth, quiet operation is normal, and a faint tick on a cold morning is nothing to worry about. Persistent clunking, grinding, or clicking, though, usually means a linkage joint needs re-greasing or, in worse cases, replacing. [4]
Time how long the board takes to fully deploy and retract, and repeat it a few times. For reference, the factory-rated deploy time is roughly 2.1 to 2.3 seconds on full-size trucks and about 1.6 seconds on mid-size trucks; retract time is about 1.1 to 1.5 seconds on full-size trucks and 1.6 seconds on mid-size trucks, with a built-in 3-second pause after the door closes before retraction begins. Consistent timing across cycles, with both ends finishing within roughly 1.5 seconds of each other, is normal. A noticeably slower end or mid-board hesitation points to motor wear or a binding linkage. [5]
Press down on each end of the deployed board with roughly 200 lb of force, about what a typical adult puts on it when stepping up. Less than 1 cm of deflection is normal. More than 1 cm, especially paired with creaking or groaning, means a loose bolt or a worn joint.
| Check | Normal | Defect Signal |
| Angle/Drop | Designed 4–5° inward slope; 1–2 cm front-to-rear height difference | > 3 cm, visually obvious tilt, or accompanied by noise |
| Deploy/Retract Sound | Smooth, quiet operation (a faint tick on cold mornings is fine) | Clunking, grinding, or persistent clicking |
| Deploy/Retract Speed | Factory deploy 2.1–2.3 s (full-size) or 1.6 s (mid-size); retract 1.1–1.5 s (full-size) or 1.6 s (mid-size); both ends finish within ~1.5 s of each other |
One end noticeably slower, or the board hesitates mid-cycle |
| Load Deflection | Less than 1 cm under about 200 lb of force | More than 1 cm deflection, with creaking or groaning |
If all four checks come back 'Normal', you're done; your board's slight tilt is exactly what it should be. If any single check lands in 'Defect', keep reading to learn how to fix it. [6] See a real-world demonstration of the deploy behavior right here.
Normal tilt becomes a real problem in three common cases. Each one has a distinct symptom and a specific fix. Once you've identified the failed check, the repair should seem straightforward.
Fix: Replace the motor. [5] [6] As a benchmark, the factory single-motor unit is rated at about 61.1 N·m of forward output torque and 56 N·m of reverse output torque, with IP67-rated sealing against dust and water, and it is pre-assembled to the bracket at the factory so the user does not need to mount the motor themselves. When a motor starts struggling, the rear end of the board tends to show increased tilt first. It is already getting the least torque, making it more like an early warning sign before the motor fails.
Keeping running board tilt within the normal range comes down to a four-step maintenance schedule. Each step fits naturally into your ownership cycle. Prevention is significantly cheaper than repair, and none of the steps take more than 15 minutes. [3]
Road salt, detergent residue, and grit all accelerate joint wear over time. After washing your truck, run the deploy-and-retract cycle two or three times. Rinse the linkage area with a low-pressure hose. It flushes contaminants out of the pivot points before they can harden into the joint grease.
Apply NLGI #2 lithium grease to all four pivot joints: the front motor bracket, the front linkage arm, the connecting rod ends, and the rear linkage arm. Worn, dry joints amplify the natural tilt and create the clunking sound. So it's the single highest-leverage maintenance task on the whole list.
Front and rear bracket bolts lose 5 to 10 percent of their torque over a year of ordinary road vibration. Use a torque wrench to bring them back to 24 Nm in a diagonal pattern, then apply thread-locking compound. This step alone prevents most of the tilt-worsening cases covered in the FAQs below. [4]
Cold-weather road salt is the number one enemy of the linkage rod. Spray the assembly with a silicone-based or dry-film anti-corrosion coating before the first freeze of the season. Skip wet lubricants here, since they attract grit and can freeze solid below about -10°C. Single-motor power running boards are factory-rated to operate from about -40°C up to 80°C on full-size trucks and from about -30°C up to 80°C on mid-size trucks, so cold-weather deployment is well within design limits. The linkage itself, however, still benefits from this extra layer of winter protection, because road salt and freeze-thaw cycles attack the joint grease faster than the motor electronics. [6]
No, chasing perfect flatness on your running boards usually makes things worse. The 4 to 5 degree inward slope is a deliberate design choice for body posture, anti-slip grip, drainage, and clearance around the chassis. Forcing a dead-level adjustment fights the design intent instead of working with it. Trying to eliminate every last millimeter of that natural lean means over-tightening one side of the linkage. Alternatively, it can shim a bracket in a way it wasn't designed for. Both put uneven stress on joints that should move freely. That extra stress accelerates the kind of wear discussed in the 4-point diagnostic checklist. It turns a cosmetic non-issue into a mechanical one. Wolfbox's power running boards on an F-150 Lightning held up reliably through repeated testing. [4] [6] The deploy mechanism needed zero adjustments beyond the standard installation. That's exactly the outcome a properly mounted, unmodified system should deliver. [7] If your board passes all four checks, the smartest move is to leave it alone.
No. You install running boards according to the manufacturer vehicle-specific mounting instructions — the brackets mount to the truck frame using factory-existing holes with bolts or clamp nuts, so no drilling is required. Any slope you see after deployment is the intentional 4 to 5 degree inward design, not something the bolting introduced.
Use a tape measure or ruler to check the front-to-rear height difference on the deployed board. The board is designed with a 4 to 5 degree inward slope, so a 1 to 2 cm difference is within normal mechanical tolerance. Anything beyond roughly 3 cm, especially with noise, is worth investigating further.
You can try, but it is not recommended. The 4 to 5 degree slope is built in for body posture, anti-slip grip, drainage, and chassis clearance. Forcing a perfectly flat board means over-tightening one side of the linkage or shimming in ways the system was not designed for, which accelerates joint wear.
Run through the 4-point diagnostic check first to confirm it has crossed from normal into a defect. Then match your symptoms to one of the three failure cases and apply the corresponding fix with the right tool(s).
The 4 to 5 degree inward slope is built in for four reasons. First, it matches the natural angle of the lower leg when stepping on and off, so the ankle does not have to twist. Second, gravity pulls the foot toward the body, which improves anti-slip grip on the board. Third, rain, wash water, and debris drain toward the body side rather than dripping off the outer edge. Fourth, the slope frees up vertical space for the motor and linkage, and helps the board tuck closer to the body when retracted to reduce wind drag.
Factory-rated deploy time is roughly 2.1 to 2.3 seconds on full-size trucks and about 1.6 seconds on mid-size trucks. Retract time is about 1.1 to 1.5 seconds on full-size trucks and 1.6 seconds on mid-size trucks. There is a built-in 3-second pause after the door closes before the board retracts, and speed adjustment is not user-configurable on the current model.
The motor carries an IP67 rating against dust and water ingress, and it is pre-assembled to the bracket at the factory. You do not need to mount the motor or do any wiring beyond connecting the harness to the vehicle. The control unit reads the door status directly from the factory CAN bus by tapping the CAN-H and CAN-L signal lines, so it does not interfere with the original vehicle electronics.
[1] Ford Truck Enthusiasts Forums, "Running Boards Angling Down," -
https://www.ford-trucks.com/forums/1678145-running-boards-angling-down.html
[2] Pickup Truck Talk: "How Running Boards Improve Vehicle Safety and Accessibility" – https://pickuptrucktalk.com/2025/11/how-running-boards-improve-vehicle-safety-and-accessibility/
[3] 4WheelParts: "The Do's and Don'ts of Running Board Installation" – https://www.4wheelparts.com/articles/the-dos-amp-donts-of-running-board-installation
[4] Wolfbox Gears: "Wolfbox Power Running Boards" – https://gears.wolfbox.com/collections/power-running-boards
[5] Wolfbox Gears: "Truck Steps Running Boards Ground Clearance"- https://gears.wolfbox.com/blogs/news/truck-steps-running-boards-ground-clearance
[6] PR Newswire: "Wolfbox Expands Beyond Dash Cams with E-RB01 Power Running Boards" – https://www.prnewswire.com/news-releases/wolfbox-expands-beyond-dash-cams-with-e-rb01-power-running-boards-combining-smart-automation-and-high-durability-302755847.htm
[7] Transport Evolved: "Wolfbox Power Running Boards: Fancy Upgrade, Or Usable Add-On?" – https://transportevolved.com/2026/07/30/wolfbox-power-running-boards-fancy-upgrade-or-usable-add-on
Comments
