Do Truck Steps and Running Boards Affect Ground Clearance?
Published on
Time to read 8 min
Fixed nerf bars and side steps hang permanently below your rocker panels, reducing effective ground clearance by 2 to 5 inches in most cases
Power running boards and retractable bed steps fold away when not in use, so they don't cut into your clearance on the trail
Most full-size trucks come with 8 to 10 inches of factory ground clearance; losing even 2 or 3 inches to a fixed step can cause hang-ups on rocky or rutted terrain
The style of step matters more than most truck owners expect, especially if you split time between street driving and off-road use
Choosing a retractable option lets you get convenient access without giving up the clearance your build actually needs
If you've ever scraped the underside of your truck on a rocky trail in the Arizona desert or clipped something crawling up a logging road in the Pacific Northwest, you already know how much ground clearance matters. It's one of those specs that doesn't get much attention until it suddenly does.
So when you're shopping for truck steps or running boards, it's fair to ask: do they lower your effective ride height? Do they change how your truck handles off-road obstacles? The answer depends entirely on what style of step you choose, and getting that choice wrong can cost you clearance you didn't know you were giving up.
What Ground Clearance Actually Means for Your Truck
Ground clearance is the distance between your truck's lowest fixed point and the ground. That could be a differential cover, a crossmember, or the frame itself, depending on the truck. It's measured at the lowest point when the truck is sitting at normal ride height.
For most full-size pickups, factory ground clearance runs between 8 and 10 inches. A stock Ford F-150 sits around 8.9 inches. The Toyota Tacoma comes in near 9 inches. The Chevy Silverado 1500 is typically around 8.1 inches. Those numbers give you decent room for trail use, but every inch matters when you're crossing rocks, rutted two-tracks, or washed-out switchbacks in the Midwest or Southwest.
And that's exactly where aftermarket steps become part of the conversation.
How Fixed Side Steps and Nerf Bars Reduce Clearance
Traditional side steps and nerf bars mount permanently below the door sills and don't move. They look good, they hold up well, and they do exactly what they're supposed to do when you're stepping in and out of the cab.
But on the trail, they become the lowest point on your truck's side. That's where you'll hang up.
Most fixed step designs position the step between 3 and 6 inches below the rocker panel, depending on the truck model, step style, and mounting geometry. If your rocker clearance is 9 inches and the step drops 4 inches below it, your effective clearance on that side drops to 5 inches. That's tight territory on anything more aggressive than a gravel road.
It's not a dealbreaker for every truck owner. If you're mostly running improved forest service roads, launching boats, or hauling gear on the weekends, fixed steps work great. But if you're running technical trails, you're giving up clearance you probably don't want to give up.
Retractable Options: The Clearance-Friendly Solution
Here's where the conversation shifts.
Power running boards and retractable bed steps are designed to get out of the way when you don't need them. Power boards deploy automatically when you open the door and retract flush against the vehicle when the door closes. On the trail, they stay tucked up where they can't catch on anything.
Our power running boards work exactly this way. They're built for truck owners who want the convenience of a running board without sacrificing off-road performance. Closed door, retracted board, no clearance penalty.
Retractable bed steps follow the same idea. They stay tucked under the bed until you kick them out or deploy them manually. When you're done loading gear, they fold back up. No hardware hanging down, no reduced clearance at the rear of the truck.
That combination of functionality and clearance preservation is why retractable steps make so much more sense for trucks that see both pavement and dirt.
Fixed Steps vs. Retractable Steps: Side by Side
Fixed Side Steps / Nerf Bars
Retractable Steps / Power Boards
Deployment
Always extended
Auto-deploy and retract
Ground clearance impact
Reduces by 2 to 5 inches
None when retracted
Installation complexity
Moderate
Moderate to advanced
Price range
Lower upfront cost
Higher upfront cost
Best for
Daily driving, mild terrain
Mixed use, off-road, overlanding
Pros and Cons
Fixed Side Steps
Pros
Lower cost with a wide range of styles available
Straightforward installation with basic tools
Low maintenance with no electrical components
Sturdy, reliable step-up for daily use
Cons
Permanently reduces your effective ground clearance
Can catch on obstacles, rocks, or trail debris
Adds a fixed profile below the cab that you can't change
Can collect mud and debris on dirty trails
Retractable Steps and Power Running Boards
Pros
Zero clearance impact when the boards are folded up
Auto-deployment is a real convenience upgrade for frequent use
Trail-ready without removing hardware or swapping parts
Cleaner appearance when tucked away on the trail or in tight spots
Cons
Higher upfront cost than fixed steps
Power boards require an electrical connection during install
More moving components than a fixed step
Overkill if you never take the truck off-road
A Note on Regulations and Modifications
This is something worth knowing before you buy. Aftermarket steps and running boards, on their own, don't violate NHTSA Federal Motor Vehicle Safety Standards. But some states have rules around vehicle height modifications or added protrusions below the frame, so it's worth checking your state's vehicle modification statutes before installing anything that significantly changes your truck's clearance profile.
The Specialty Equipment Market Association (SEMA) is a good resource for U.S. truck owners stacking multiple aftermarket upgrades. They maintain updated guidance on modification compliance and state-specific rules for the aftermarket industry.
Find the Right Retractable Bed Step for Your Truck
We've built our truck steps specifically around the trucks that use them. Each one is a direct fit for the model it's designed for, no trimming required, no guesswork on mounting.
Not sure if a specific product fits your exact build? Our guaranteed fit promise has you covered. If it doesn't fit your rig, it's on us.
So Which Setup Is Actually Right for You?
It comes down to how you use the truck.
If you're driving paved roads and mild dirt paths, hauling loads, or shuttling the family around, fixed steps are affordable and practical. They do the job without any added complexity.
But if you're running a Silverado through muddy work sites in Texas, a Tundra on trails in the Sierra Nevada, a Tacoma through the Cascade foothills in Washington state, or a Gladiator across the Colorado Rockies, you don't want fixed hardware eating into your clearance. Retractable steps solve that problem without asking you to choose between convenience and capability.
Serious off-road builds treat ground clearance as a priority, not an afterthought. A good retractable step is one of those practical upgrades that keeps the truck trail-ready without changing how you use it day to day. Check out our installation resources if you want to get a feel for what's involved before you buy.
Ready to Step Up?
Browse the full lineup of WOLFBOX Gear truck steps and find the retractable option built for your specific truck. Every product ships with a guaranteed fit, and our team of specialists is available if you have questions before you order. Reach us at gears@wolfbox.com or call +1 888-432-7508, Monday through Friday, 9AM to 7PM.
Do running boards reduce ground clearance?
Fixed running boards do reduce ground clearance because they hang permanently below the rocker panels. Power running boards and retractable designs don't reduce clearance when they're folded up, making them a better fit for trucks that go off-road.
How much clearance do truck steps take away?
It depends on the design. Fixed side steps typically position 3 to 6 inches below the rocker panel, which directly reduces your effective side clearance by the same amount. Retractable steps and power boards take away zero clearance when folded up, since they're tucked flush against the truck.
Are retractable running boards better for off-road use?
In most cases, yes. Retractable boards fold away when not in use, so there's no hardware hanging down to snag on obstacles or reduce your approach and departure angles on the trail. For mixed-use trucks, they're a practical upgrade over fixed steps.
Do truck bed steps affect ground clearance?
Retractable bed steps don't affect ground clearance when they're deployed back into the bed. They stay tucked away flush until you need them. Fixed rear bumper steps can add a minor protrusion at the rear, but they don't create the same clearance concerns as permanent side-mounted steps.
What's the ground clearance on a stock F-150?
A standard Ford F-150 has roughly 8.9 inches of ground clearance from the factory. That can vary slightly by trim, cab configuration, and suspension setup. A fixed step that drops 4 inches below the rocker panel can significantly reduce effective side clearance, especially when the truck is flexed on uneven terrain.
Can I install a retractable bed step myself?
Most of our retractable bed steps are designed for DIY installation using basic hand tools, with no drilling required in most cases. We also provide step-by-step truck bed step installation guides to walk you through the process.
Do running boards void my truck warranty?
Generally speaking, aftermarket running boards and steps don't void your vehicle warranty on their own. Under the Magnuson-Moss Warranty Act, a dealer would need to prove that a specific aftermarket part caused a specific failure in order to deny coverage for that component. That said, it's always a good idea to check with your dealer before adding modifications that tie into factory electrical systems, like power running boards.
I took a bad fall six years ago and I cannot lift my leg to get it in my 2020 Lincoln NAUTILUS Wood, adding running boards help me be able to step into my car so I can drive in order to get in my car to drive or passenger I must sit in my car and then lift my legs by pulling them up by my pants. I am a senior citizen and need help. Thank you.
Scroll to the top of the page
Choosing a selection results in a full page refresh.
