Side Mirror Truck Price: What OEM and Aftermarket Options Really Cost
Time to read 8 min
Time to read 8 min
OEM dealer mirrors cost more mainly because of built in electronics like heating, power fold, turn signals, and blind spot sensors, not just the glass itself.
Labor typically runs $75 to $150 an hour, and camera based blind spot systems may need separate recalibration after a mirror swap.
Aftermarket wide angle mirrors, like WOLFBOX Gear Wide-Angle Convex Side Mirrors, can improve visibility for a fraction of a full OEM assembly's price.
Your final side mirror truck price depends on your specific trim, whether you need the whole housing or just the glass, and who does the installation.
If you've ever caught your side mirror in a garage doorframe, backed into a mailbox, or watched a piece of gravel crack your glass on the highway, you already know the sinking feeling. Now what? Suddenly you're staring down quotes that range from $60 to $1,800, and none of it makes sense at first glance.
Here's the thing. Side mirror truck price isn't one number. It's a range that shifts based on your truck's trim level, how many electronics are packed into that mirror housing, and whether you go through a dealer, a parts store, or an aftermarket brand. We're going to walk through exactly where that money goes, dimension by dimension, so you can make a decision that fits your budget and your rig.
Let's start with the part itself, since that's usually the biggest swing factor.
A bare bones manual mirror glass replacement can run as little as $10 to $30. That's the cheap end. But most trucks on the road today, especially anything built in the last decade, come with power adjustment, heating elements, integrated turn signals, and sometimes a blind spot monitoring sensor tucked into the housing. Add those features together and the part price climbs fast.
Genuine OEM mirror assemblies for popular trucks commonly list between $115 and $300 for simpler setups, but heated units with blind spot detection can run $479 to $568 or more depending on the make and trim. Generic aftermarket replacement mirrors, by contrast, often sell for $40 to $150 for the same fitment, though you're usually trading away some of the electronics along with the price cut.
So why the gap? OEM parts are manufactured to match your exact trim's wiring harness, connector pinout, and factory paint code. That precision costs money. Aftermarket parts skip some of that customization, which is exactly why price and features don't always line up one to one between brands.
Parts are only half the bill. Labor is the other half, and it varies more than most truck owners expect.
Auto repair shops typically charge $75 to $150 per hour, and a straightforward mirror swap takes 0.5 to 2 hours depending on how the door panel comes apart. On some trucks, you're just popping a few screws. On others, you're pulling interior trim, disconnecting airbag wiring, and hoping none of the one time use clips snap in your hand.
If your truck uses a camera assisted blind spot system, add another wrinkle. Recalibration after a mirror change can run anywhere from $75 to $725, according to cost data compiled from RepairPal and ShopEarl. That's not a small add on. For some owners, calibration alone costs more than the mirror.
DIY installation obviously saves the labor line entirely. Simple bolt on aftermarket mirrors, like the ones designed for direct OEM mount points, are often a 10 to 30 minute job with basic hand tools. Full OEM assembly swaps that involve interior trim and wiring take longer and carry more risk if you're not confident working around your dash.
This is where side mirror truck price starts to make more sense. You're rarely just paying for glass and plastic.
Heated glass. Integrated turn signal lighting. Auto dimming. Power fold for tight parking. Blind spot detection sensors. Puddle lights. Every one of these features adds cost, and stacking two or three of them on a single mirror can double what you'd pay for a basic manual unit.
Here's a rhetorical question worth asking yourself before you buy: do you actually need every feature your factory mirror had, or are you replacing it because something broke and you just want reliable, wide field of view again?
For a lot of truck owners, especially those running trails in the Southwest desert or hauling gear through Midwest job sites, the priority isn't auto dimming glass. It's a wider, clearer view of what's next to and behind the truck. That's a different problem than matching every factory feature dollar for dollar, and it opens the door to aftermarket options that solve visibility first.
WOLFBOX Gear Wide-Angle Convex Side Mirrors take that approach. They're built as a direct glass replacement that snaps into your factory mirror base, no drilling or cutting required, and they widen your field of view by roughly 30 percent using R1200 convex optics. Standard heating comes built in on every pair, with an optional anti glare blue tint available for drivers dealing with harsh headlight glare on Pacific Northwest logging roads or long interstate hauls at night. They're designed for a wide range of off road vehicles, not just trucks, so the same core technology fits Jeeps and SUVs too.
A cheap mirror that rattles loose after a few months of washboard roads isn't actually cheap. It's a mirror you'll buy twice.
Fit quality matters more than most buyers realize going in. OEM parts are engineered to snap into your exact factory mounting points, which is part of why they cost more. Some aftermarket options are stick on units that sit loosely over your existing glass, and those tend to shift, fog, or peel over time, especially with temperature swings.
Others are full replacement units built with a rigid backing plate that mounts the same way the factory piece does. That distinction matters a lot once you're a year or two past installation. WOLFBOX Gear backs its Wide-Angle Convex Side Mirrors with a 3 year limited warranty against structural and workmanship defects, which gives you a longer runway than most stick on alternatives offer.
One more thing worth knowing. Warranty length is often a better signal of expected lifespan than sticker price alone.
OEM Dealer Assembly |
Aftermarket Wide-Angle (WOLFBOX Gear) |
Typical part price |
$115 to $600+ depending on features |
$69.99 per pair, regular price $99.99 |
Labor and install |
$75 to $150/hr, 0.5 to 2 hours at a shop |
Roughly 10 to 30 minutes, direct bolt on fit |
Heating |
Included on most modern trims |
Standard on every pair |
Field of view upgrade |
Matches factory spec, no widening |
Approximately 30 percent wider with R1200 convex optics |
Blind spot calibration |
May be required, $75 to $725 |
Not applicable; upgrade compatible on select fitments |
Warranty |
Varies by dealer and part source |
3 year limited warranty |
Best for |
Owners who need exact factory match, including cameras |
Owners who want wider visibility at a lower total cost |
Pricing varies by vehicle and current promotions, so always confirm the exact fitment and cost for your specific year and trim before buying.
If your truck relies on a camera integrated blind spot system or lane keep assist tied directly into the mirror housing, OEM is often the safer, if pricier, route. You're paying to keep every factory safety system working exactly as designed.
But if your factory mirror is intact and you're upgrading purely for visibility, or your mirror glass cracked and the housing is fine, an aftermarket wide angle replacement gets you most of the functional benefit for a lot less money and a much shorter install time. Drivers dealing with tight trailer backing, technical rock crawling sections, or simply merging on crowded interstates tend to notice the wider field of view immediately.
If you're shopping for a specific fitment, WOLFBOX Gear makes Wide-Angle Convex Side Mirrors for the Ford F-150 and F-150 Lightning, Wide-Angle Convex Side Mirrors for the Chevy Silverado 1500, 2500 HD, and 3500 HD, and Wide-Angle Convex Side Mirrors for the Jeep Wrangler JL and Gladiator JT, among others. Full installation steps, including what tools you'll need, are laid out in the Wide-Angle Convex Side Mirrors installation guide if you want to see the process before you buy.
You don't have to choose between an inflated dealer quote and a flimsy stick on mirror that fogs up by winter. If you're ready to trade blind spots for a wider, clearer view of the road and trail behind you, browse the WOLFBOX Gear Wide-Angle Convex Side Mirrors collection and find the fit for your rig. Whether you're prepping for a weekend trail run or just tired of guessing what's in your blind spot on the daily commute, it's a straightforward upgrade that doesn't require a trip to the dealer.
Costs range widely. A basic manual mirror can run under $100 total, while a fully loaded OEM assembly with heating, power fold, and blind spot detection can cost $600 to $1,800 or more once labor and possible camera calibration are added.
Replacing only the glass is almost always cheaper, often $10 to $30 for the part, but it only works if the housing, motor, and wiring are undamaged. If the housing is cracked or the electronics failed, you'll need a full assembly.
It depends on the product. Some aftermarket mirrors are designed to be compatible with existing blind spot sensors, while basic stick on or glass only replacements typically don't interact with that system at all. Always check the specific fitment notes before buying if you rely on blind spot detection.
Many bolt on aftermarket mirrors are designed for a straightforward DIY install in under 30 minutes with basic hand tools. Full OEM assembly swaps that involve interior door panels and airbag wiring are more involved and may be better left to a professional if you're not comfortable working around those components.
Federal Motor Vehicle Safety Standard No. 111 permits convex mirrors on the passenger side of most cars and light trucks, provided the radius of curvature falls within a specific range set by the standard. Always confirm your state's specific requirements and the manufacturer's compliance details before installing an aftermarket mirror.
A simple bolt on glass or mirror unit installation generally takes 10 to 30 minutes. A full OEM assembly replacement involving interior trim removal can take an hour or two at a shop.
It depends on your policy and how the damage happened. Comprehensive coverage often applies to vandalism, weather, or animal related damage, while collision coverage may apply if you hit something. Check with your insurance provider for your specific situation, and factor in your deductible before filing a claim for a lower cost repair.
