How to Add a Retractable Truck Bed Step to Your Toyota Tundra
Published on
Time to read 9 min
  • Our retractable truck bed step mounts on the truck's existing frame and bumper studs at the driver-side rear corner of the truck, and swings out with a nudge of your boot.
  • Before you order, check three things: your model year, your trim (TRD Pro isn't covered), and your exhaust (factory dual or aftermarket exhaust blocks the mount).
  • The install uses factory mounting points, so there's no drilling, and most owners finish in about 30 minutes with basic hand tools.
  • A good step gives you a 5-inch drop, a wide anti-slip pad, and a static rating you can trust. Ours is rated for 330 lbs.
  • Once it's retracted, the step tucks up under the bumper and stays out of the way on the trail.
How do you get into your Tundra's bed right now?
For a lot of owners, it's a foot on the rear tire, a hand on the bed rail, and a hop. Or you drop the tailgate and climb up like it's a loading dock. Both work. Neither is great when the tire's wet, your hands are full, or your knees have a few hundred thousand miles on them.
The third-generation Tundra sits tall, and 4x4 models sit taller still. That's great for clearance and towing. It's not so great when you just want to grab a cooler from the front of the bed.
A retractable truck bed step fixes that. Below, we'll cover how these steps work, how to confirm fitment on your Tundra, and the full install from box to first step.
Why a Truck Bed Step Makes Sense on a Tundra
The Tundra has a deep bed and high bed rails. Reaching anything past the wheel wells usually means climbing in. If you haul firewood in the Pacific Northwest, run a camping setup out of the bed in Utah, or load feed sacks on a Texas ranch, that's a lot of climbing in a week.
Climbing on the tire is the default move. But tires are round, often muddy, and not built to be a stepladder.
Falls are a bigger deal than most people give them credit for. OSHA's walking and working surfaces rule, found in 29 CFR 1910 Subpart D, exists in part because falls from heights and on the same level are among the leading causes of serious work injuries. The same idea applies at your tailgate: a flat, solid, grippy place to put your foot beats an improvised one.
A truck bed step on a Tundra gives you that platform right where you need it. And when you don't need it, it disappears.
How a Retractable Truck Bed Step Works
There's no motor, no wiring, and no battery drain, because it's all mechanical.
The step sits folded up under the rear bumper on a spring-loaded linkage arm. Push it down with your boot and it swings out into position. When you're done, give it a nudge and the spring pulls it back up and out of sight.
Here's what the WOLFBOX Gear Retractable Bed Step for the Toyota Tundra brings to the table:
  • 330 lbs static capacity, so a full-grown adult carrying gear has plenty of headroom.
  • A 6-inch-wide pad with an aggressive anti-slip texture for wet boots, mud, and snow.
  • A 5-inch drop, which turns a big leap into a normal step.
  • Die-cast aluminum with an e-coat and black powder coat to fight rust and road salt.
  • A 3-year warranty on the step itself.
Because it's purely mechanical, there's nothing to short out after a creek crossing or freeze up because a sensor got packed with ice on a January morning in Montana. Fewer parts. Fewer things to fail.
Check Fitment Before You Order
This is where most mistakes happen, so slow down here.
Model Year
Our Tundra step is built for the third-generation truck (2022-2027). It won't fit 2007 to 2021 Tundras, since the frame and rear bumper are different.
Trim Level
TRD Pro models are not compatible, and neither are trucks with a factory dual exhaust or an aftermarket exhaust system. Beyond that, fitment is confirmed by model year rather than by trim badge, so a trim name alone does not settle it.
Not sure exactly which trim or package you have? Your window sticker or Toyota's official Tundra page can help you match it up.
Exhaust
This one catches people off guard, because the step mounts on the driver side only, right where an exhaust tip might sit. If your truck has a factory dual exhaust or any aftermarket exhaust, the step won't fit. Take a quick look under the rear bumper before you order.
If any of that is unclear, give our team a call before you buy. When you shop by vehicle on our site, your order is backed by the WOLFBOX Gear Guaranteed Fit promise, so you're not stuck guessing.
Tools and Parts You'll Need
You don't need a lift. You don't need a drill. In most cases, a driveway and the tools already in your garage will do.
Tools:
  • Ratchet with extensions
  • 24mm socket
  • 13mm socket and 13mm wrench
  • A 1/4 inch drive ratchet with a short socket for the tight spot behind the linkage arm
  • Work gloves (one pair comes in the box)
What's in the box:
  • Linkage arm assembly
  • Frame mounting bracket
  • Support bracket
  • Aluminum step pad
  • Hardware kit with bolts, T-bolts, washers, and nylon lock nuts
Lay everything out on a piece of cardboard before you start. It sounds basic, but it saves you from hunting for a washer in the gravel later.
How to Install a Truck Bed Step on Your Tundra
Here's the general process. Your kit includes a Tundra-specific instruction sheet, and our truck bed step installation guide has videos for each stage. Follow the Tundra sheet wherever it differs from what you see in the videos, since hardware locations can vary a bit from truck to truck.
Step 1: Pre-Assemble the Brackets
Line up the frame mounting bracket and the support bracket, then join them with the two combo bolts from your hardware kit. Leave those bolts a little loose, so you have some wiggle room once the brackets are on the truck. The exact bolt specs that ship with your unit are listed on the Tundra instruction sheet in the box - follow that sheet, because hardware can change between production runs.
Step 2: Remove the Factory Hardware
Head to the driver side rear corner and look up behind the bumper. Remove the factory nuts and bolts at the mounting points your instruction sheet calls out. On the trucks shown in our install videos, that's two 24mm frame nuts plus two 8mm flanged bolts higher on the bumper structure, which come off with a 13mm socket. Keep track of which hardware gets reused and which doesn't. The sheet spells it out.
Step 3: Mount the Brackets
Raise the bracket assembly into place over the factory mounting points and reinstall the hardware to hold it. Snug everything, then check that the bracket sits square to the bumper. Now go back and tighten the combo bolts you left loose in Step 1.
Step 4: Attach the Linkage Arm
Fit the linkage arm to the bracket. Fasten the top with the hex bolt, lock washer, and flat washer from your kit, and secure the side with the two combo bolts from your kit.
Step 5: Install and Position the Step Pad
Slide four T-bolts into the two channels on the underside of the step pad, two per channel, then set the pad on the linkage arm and loosely thread on the four flat washers and four nylon lock nuts from your kit.
Step 6: Test It
Kick it out. Step on it with your full weight. Nudge it back up. Do that a few times and make sure it deploys and retracts smoothly without rubbing on the bumper or anything nearby.
So that's it, and in most cases you're done in about half an hour.
Retractable Step vs. Other Ways Into the Bed
You've got a few options for getting into a Tundra's bed. Here's how they generally stack up.
Hitch Step
Tailgate Ladder
Where it mounts
Under the rear bumper
2-inch receiver hitch
On the tailgate
Stays on the truck
Yes, tucks away
Must come off to tow
Folds onto tailgate
Works with tailgate closed
Yes
Yes
No
Ground clearance impact
None when retracted
Hangs below the bumper
None
Fit
Vehicle-specific
Universal
Semi-universal
Best for
Daily bed access and towing rigs
Occasional use
Frequent full climbs into the bed
Do you tow a camper or a boat most weekends? Then a hitch step gets old fast, since it has to come out every time you hook up, while a bumper step stays put and out of the way of your hitch.
Living With a Bed Step on Your Tundra
Once it's on, you'll probably use it more than you expect. Grabbing a tool bag at a job site. Pulling a cooler forward before a game day tailgate.
A few tips to keep it working right:
  • Rinse it after winter. Road salt is hard on any moving part. A quick spray at the car wash goes a long way.
  • Step on it, don't jump on it. The 330 lb rating is a static load. Jumping can push forces well past your body weight.
  • Check the hardware once in a while. Generally speaking, a quick look every oil change is plenty.
  • Retract it before you drive. It won't hurt anything to forget once, but get in the habit.
Thinking about other upgrades that make a tall truck easier to live with? The WOLFBOX Gear Power Running Boards for the Tundra handle the cab side of the climbing problem. If you want the bed covered too, the WOLFBOX Gear SmartSlide Electric Retractable Bed Cover for the Tundra keeps your gear dry and locked up.
Will a Bed Step Affect Your Tundra's Warranty?
It's a fair question. In general, a bolt-on accessory that uses factory mounting points and doesn't involve drilling, cutting, or wiring doesn't permanently change your truck. Under the federal Magnuson-Moss Warranty Act, which the Federal Trade Commission enforces, a manufacturer generally can't void your warranty just because you installed an aftermarket part. They'd typically need to show that the part caused the problem in question.
We're not lawyers, though. If you have a specific warranty concern, your dealer's service department is the right place to ask.
Find the Right Truck Bed Step for Your Tundra
If you're tired of climbing your rear tire every time you need something from the bed, a retractable step is one of the simplest upgrades you can make. Browse WOLFBOX Gear truck steps, select your Tundra, and you'll see what fits. Questions about your trim or exhaust? Our specialists are at 888.432.7508 or gears@wolfbox.com, and they're happy to double-check fitment before you order.
Step Up. Get Out There.
Will a retractable bed step fit my Toyota Tundra?
The WOLFBOX Gear Retractable Bed Step fits 2022-2027 Tundras, excluding TRD Pro models. It mounts on the driver's side and won't fit trucks with a factory dual exhaust or an aftermarket exhaust. If you're unsure about your truck, check the fitment table on the product page.
Do I have to drill to install a truck bed step on a Tundra?
No. Our bed steps reuse the original factory frame nuts and bumper studs, with no drilling, cutting, or welding needed.
How long does it take to install a bed step on a Tundra?
Most owners finish in about 30 minutes. You'll need a ratchet, extensions, 24mm and 13mm sockets, a 13mm wrench, and ideally a 1/4 inch ratchet for the tight linkage arm bolts. No lift required.
How much weight can a Tundra bed step hold?
The WOLFBOX Gear Retractable Bed Step is rated for 330 lbs static. Step onto it rather than jumping, since a jump can put several times your body weight on the step.
Does a retractable bed step reduce ground clearance?
Not when it's retracted, since the step tucks up under the rear bumper and doesn't hang below the bumper line, so it shouldn't change your departure angle on the trail.
Can I still tow with a bed step installed?
Yes. Unlike a hitch step, a bumper-mounted bed step doesn't use your receiver, so you can hook up a trailer without removing anything.
