WOLFBOX GEAR ENGINEERING
COMMAND THE VIEW
Shatter your blind spots. Panoramic optics for absolute situational authority.
+30%
EXPANDED VIEW
Convex wide-angle glass entirely eliminates blind spots. Stop craning your neck.
BSM
INTEGRATION
Seamlessly works with your factory Blind Spot Monitoring system. Keep the tech.
NANO
ANTI-GLARE
Optional blue glass naturally filters out blinding high beams. Rule the night.
OEM
DEFROST READY
Plugs directly into your factory heating circuit to instantly melt frost and fog.
NO MORE TUNNEL VISION.
COMMAND THE NIGHT.
Don't let massive blind spots or blinding high beams dictate your drive. Our Wide-Angle Convex Mirrors are engineered to give you absolute situational awareness, whether hauling heavy or cruising the highway.
  • Up to 30% Wider Horizon
    Our engineered convex glass aggressively stretches your field of view. Spot obstacles and trailing vehicles sooner, completely eliminating blind spots without craning your neck.
  • Stop Getting Blinded (Upgrade Option)
    Tired of aggressive high beams in your eyes? Upgrade to our nano-coated blue glass. It filters out harsh glare naturally and instantly, without the lag of electronic sensors. Night driving just got comfortable.
KEEP YOUR FACTORY TECH.
WINTER-PROOF YOUR RIDE.
A massive view upgrade shouldn't mean downgrading your truck's smart features. We built these mirrors to perfectly plug-and-play with your existing OEM safety systems.
  • Seamless BSM Integration
    Retain your factory Blind Spot Monitoring system. If the sensor detects a vehicle, the precise indicator seamlessly lights up through the glass. No features compromised.
  • Frost? Fog? Gone.
    Winter-proof your rig. This standard feature connects directly to your OEM heating circuit for fast, reliable defrosting. Don’t roll down your window in freezing temps just to wipe your mirror. Just drive.
Seamless Blind Spot Monitoring and Defrost Integration
SELECT YOUR FITMENT
Precision engineered for specific truck and SUV models. Choose yours.
We've Got Your Back
Why should I upgrade my factory flat driver-side mirror to a wide-angle convex mirror?
Upgrading eliminates massive, dangerous blind spots caused by standard US flat mirrors. Our engineered convex glass aggressively stretches your field of view by up to 30%. This allows you to spot trailing vehicles and obstacles much sooner without constantly craning your neck.
What is the advantage of choosing the blue-tinted side mirror over the standard clear glass?
The blue glass option features a specialized nano-coating designed to stop blinding glare from aggressive high beams and tall trucks at night. It filters out harsh light naturally and instantly, completely without the lag of electronic auto-dimming sensors, making night driving significantly more comfortable.
Will replacing the mirror glass disable my truck's factory Blind Spot Monitoring (BSM) system?
No, your factory safety tech remains fully functional. If your vehicle supports it, you can select the BSM-compatible option. The OEM sensors are retained, and when a vehicle is detected, the precise LED indicator seamlessly lights up directly through the new glass.
Do these aftermarket convex mirrors support the original heated defrost function for winter driving?
Yes, they are completely winter-proof. The mirrors connect directly to your truck's existing OEM heating circuit for fast and reliable defrosting. This plug-and-play standard feature ensures that frost and fog are quickly eliminated, so you never have to roll down windows in freezing temperatures.
Can I install these replacement mirror glasses myself without breaking the internal power adjustment motor?
Yes, installation is straightforward if you use finesse rather than force. By tilting the mirror to create a gap and using a plastic pry tool, you can safely pop the old glass off its backing plate clips without damaging the delicate power adjustment motor underneath.
Can I customize these side mirrors based on my truck's specific trim level and features?
Absolutely. We offer fully customizable upgrade options tailored to your specific rig. You can select either the standard clear lens or the anti-glare blue glass. Additionally, you can choose versions with or without the integrated blind spot warning light, matching your exact factory OEM capabilities.
