STEP THE RUGGED
Step up effortlessly. Hidden strength that supports you and your heavy gear every time.
FIND YOUR FITMENT
SaleFord F-150(21-27) | Lightning(22-25) | F-250/F-350/F-450/F-550 (22-27)
SaleFord F-150 (15-20) | F-250/F-350/F-450/F-550 (17-19) | Crew Cab
Sale
Sale
Sale
Sale
SaleChevy/GMC 1500 (22-26) | Chevy/GMC 2500 HD/3500 HD (24-27) | Crew Cab
SaleChevy/GMC 1500 (19-21) | Chevy/GMC 2500 HD/3500 HD (20-23) | Crew Cab
Sale
Sale
Sale
Sale
Sale
Sale
Sale
Sale
Sale
Sale
Sale“Overall easy install! These work flawlessly and look amazing on my Bronco. Saved $1000 compared to AMP.”
“Put these on my 2020 F250. Very happy! The whole install was less than an hour. Gives the truck a whole new look.”
“Strongly built and very quiet and smooth when moving up/down. Tucks nicely for a super clean look!”
“I replaced the narrow factory steps on my F-150 Crew Cab. Powered boards deploy low, LEDs light up, and my brother is jealous!”
“Installed on my 2026 GMC Sierra 2500 HD AT4 in 3.5 hours. Instructions clear, worked flawlessly once set up.”
“Ordered for my 2024 Ford F-150. Makes it so much easier for my wife and granddaughter to get into the truck!”
“Great product! Wiring was easy to route and everything worked the first time. Made a huge difference on my F250.”
“Installed on my 2026 Ram Warlock. Impressed by the drive motor strength. Save money over other brands with confidence.”
“Tucks under the truck just like AMP and folds down lower than RC steps. Very nice quality for the price.”
“Installed on F-250 6.7 Powerstroke. Step is wide & sturdy, extends/retracts quickly. Highly recommend!”
WHY WOLFBOX
See how Wolfbox outsmarts other power boards and factory steps.
Ergonomic step extension engineered for lifted trucks, providing the perfect stepping height.
Tested in extreme cold & thick ice. Anti-freezing lubrication prevents ice jamming.
High-torque single heavy-duty motor with hex rod transmission for smooth deployment.
Solid high-tensile steel mounting linkages guarantee uncompromising structural integrity.
| FEATURE | WOLFBOX POWER BOARDS | OTHER POWER BOARDS | FACTORY STATIC STEPS |
| Ease of Entry | ✓13”–15” drop (Model specific) | ✓Drops low | ✕Fixed, high step |
| Winter Resilience | ✓Tested down to -40°F | ⚠Can jam in ice / salt | ✓Unaffected (fixed) |
| Safety | ✓Anti-pinch + 3-sec delay | ⚠Not always included | — N/A (no moving parts) |
| Motor & Sealing | ✓IP67 sealed single-motor + CAN bus | ⚠Sealing varies | ✕No motors |
| LED Lighting | ✓Included Free | ✕Usually a paid add-on | ✕None |
| Weight Capacity | ✓660 lbs (per side) | ✓~600 lbs | ⚠Usually <500 lbs |
| Clearance | ✓Retracts fully hidden | ✓Retracts flush | ✕Fixed lower clearance |
| Warranty | ✓5-Year Limited Warranty | ⚠Varies (often 1–3 yr) | ⚠Varies |
Shortens the step distance so kids can climb into the cabin with confidence and independence—no more struggling to reach or needing a full lift every time.
