Ford F150 - Powered Retractable Bed Cover Installation Guide
Catalog
🛠️ Preparation
1
Unboxing & Inventory
Tonneau Cover Box Contents
2
Prep the Truck Bed
  • ● If your rig has factory bed-mounted utility brackets, grab a T30 Torx wrench and take them off for now.
  • ● Pop out the two plastic plugs at the front of the bed, use a 5/8" (19mm) hole saw to drill a drain hole in each, clean the edges, and snap them back in.
  • ● Wipe down the front bulkhead and plastic bed caps. Lay down the hard foam seal across the bulkhead , then stick the soft foam water-resistant seals directly on top and along the bed caps.
  • ● Roll a piece of the included mastic tape into a strip and press it firmly into the front bulkhead corners to block out water.
3
INSTALL MOTOR
4
INSTALL SIDE RAILS
5
INSTALL CANISTER COVER PLATE
⚡Wiring & Routing
6
CONNECT WIRE HARNESS
    Every harness lead is labeled and uses unique male/female connectors, making it practically foolproof.
    Plug the two large connectors on the ECU main harness directly into the bottom of the ECU.
    Match up the smaller leads on the ECU harness to their corresponding wires on the tonneau cover and side rails. Ensure they click into place.
    Use the included fastening buckles to keep your wiring neat and organized inside the canister area.
    Important: Keep the connector for the main power harness unplugged at this time.
7
ROUTE THE POWER HARNESS
    Feed the power harness out through the hole near the top driver's side of the bed, leaving about 1.5 ft. of slack in the bed.
    Run the harness down the frame and up into the engine bay to reach the battery. Secure it high up with zip ties, staying clear of hot exhaust pipes and moving parts.
    Remove the fuse from the fuse holder on the positive connector, then attach it to the main power harness.
    Important: Do not connect the power harness to the vehicle battery at this time.
7
22+ F150 LIGHTNING ONLY
Lightning Step 1 Lightning Step 2 Lightning Step 3 Lightning Step 4
    Pop off the driver-side plastic panel by twisting the plastic clips along the perimeter.
    Remove the square panel inside the front trunk (frunk) to reveal the battery.
    Route the power harness up through the driver-side wheel well and behind the front trunk tub until it reaches the battery.
    Remove the fuse from the fuse holder. Do not connect the power harness to the battery at this time.
🔌Bed Installation & Alignment
9
INSTALL TONNEAU COVER
    Grab a buddy and carefully lift the entire tonneau cover assembly onto the truck bed. Do not slide it along the bed rails, or you'll tear up those foam seals you just applied!
    Set it down leaving about a 1-foot gap from the front bulkhead.
    Plug the main power harness into the ECU connector.
    Carefully lift and nudge the cover as far forward as possible. Make sure to leave a slight gap between the canister and the front of the bed so they aren't rubbing.
10
INSTALL MOUNT BRACKETS
    Slide four 6mm T-channel blocks into the bottom channel of the side rail and line them up with your bed's mounting points.
    Grab your front and rear mount brackets and position them on the bed. If you removed factory utility brackets earlier, sandwich them right on top of these new brackets.
    Attach the brackets to the bed using the 6-1.00 x 20mm T30 Torx bolts, and to the side rails using the 16mm combo Torx bolts. Attach the support brackets using the remaining 20mm Torx bolts.
    Important: Keep all hardware loose for now—you'll need the wiggle room to align everything in the next step. Repeat on the passenger side.
11
ALIGN THE SIDE RAILS
🔩Finalizing & Powering Up
11
INSTALL DRAIN TUBES
12
FINISH INSTALLATION
Install Guide
Download
What's Included
Download
How to Use
Download
