Toyota Tundra - Power Running Boards Installation Guide
Product Categories
🛠️ Preparation
Tools Required
  • Extensions & Wrenches
  • Needle Nose Pliers(Crucial)
  • Electrical Tape
Box Contents
See Photo
  • Running Boards (x2)
  • Linkage Assemblies (x4)
  • Hardware Kit
  • Harness & ECU
  • LED Lights
1
Prepare Mounting Points
Front Mounting Area
Rear Mounting Area
  • ● Locate the Driver Side front and rear mounting points on the rocker panel under the doors.
  • ● IMPORTANT Remove the factory pre-installed OE bolts from the mounting areas before attempting to mount the brackets.
2
Pre-Assemble Brackets
  • ● Attach the mounting brackets to the linkage arms.
  • ● Insert M8 Carriage Bolts into the square slots so that the threads are pointing downwards.
  • ● Use M8 Flanged Nylon Lock Nuts to fasten the aluminum linkage arms to the brackets (4 fastening points on each).
  • ● NOTE Tighten the Lock Nuts all the way until completely tight. (Brackets pictured are for illustration purposes only).
3
Mount Front Bracket
Line up front mounting bracket slots
Place Driver Side Front Bracket Assembly
  • ● Line up front mounting bracket slots to the threaded inserts on the rocker panel.
  • ● Place the Driver Side/Left Front Bracket Assembly (A) onto the rocker panel.
  • ● Fasten using Hex Bolts (K), Lock Washers (L), and Flat Washers (H).
  • ● CRITICAL Do not tighten all the way yet. Adjustments may be needed later.
4
Mount Rear Bracket
Line up rear mounting bracket slots
Place Driver Side Rear Bracket Assembly
  • ● Locate rear mounting points. Line up the rear bracket slots to the threaded inserts.
  • ● Place the Driver Side/Left Rear Bracket Assembly (B) onto the rocker panel.
  • ● Fasten using Hex Bolts (K), Lock Washers (L), and Flat Washers (H). Do not tighten all the way yet.
  • ● TIP Use the optional C-Shims (T) between the bracket and vehicle body to help better align the front and rear assemblies if needed.
5
Fuse Safety
Remove 25A Fuse
  • ● Locate your vehicle's battery and its positive/negative terminals.
  • ● Open the fuse holder cap on the main harness (M) and remove the 25A fuse.
  • ● WARNING Keeping the fuse connected may result in electrical sparks and risk of shorting when working with the battery.
6
Power & Connectors
Connect Power Leads to Battery
  • ● Connect the positive lead to the positive terminal, and negative lead to the negative terminal. Make sure both are secured.
  • ● Connect the ECU (P) to the main harness.
  • ● Connect the Long LED Y-Harness (N1) to the Driver-side branch, and the Short LED Y-Harness (N2) to the Passenger-side branch.
Determine Your Vehicle Type for Routing
• Non-Hybrid Models: The battery is in the engine bay. Follow Step 7A.
• Hybrid Models: The battery is under the Driver Side Rear Seat. Follow Step 7B.
7A
Routing (Non-Hybrid)
Non-Hybrid Routing
  • ● Route main harness around the battery, up along the rear of the engine compartment.
  • ● Route the Driver-side branch down against the fire wall. Avoid contact with the steering column.
  • ● Route the shorter Passenger-side leg down the wheel well. Avoid moving or hot engine components.
  • ● Secure ECU using double-sided tapes near the battery away from direct heat.
7B
Routing (Hybrid Models)
Battery under seat
Hybrid ECU placement
  • ● Lift the Driver Side Rear Seat to unveil the battery space. Connect power leads here.
  • ● Route the main harness along the inside of the cabin. (May need to remove plastic paneling to hide wires).
  • ● Route Driver-side branch to the outside of the cabin to the motor. Avoid steering column and hot exhaust pipes.
  • ● Secure ECU inside the cabin away from direct heat.
8
Penetrate from Underside
Locate floor grommet underside
  • ● Under Vehicle: On the underside of the driver side, locate and remove the floor grommet in the floor panel behind the front wheel well.
  • ● The grommet will be close to the front linkage arm.
  • ● Poke a hole through the rubber grommet and thread the two signal wires through and up into the vehicle cabin.
9
Route Inside Cabin
Remove interior sill and kick panels
Pull wires through grommet
  • ● Inside Cabin: Remove the driver-side bottom door sill plate first.
  • ● Unscrew the plastic nut (if equipped) and remove the driver-side front kick panel.
  • ● Peel back the carpet to access the hole where the grommet was removed and pull the wires completely through into the cabin.
Make or Break: This step allows the running boards to "read" your door signals. Please follow carefully.
A
Locate CAN Junction
Locate CAN Junction Connector
Push locking tab to release
  • ● Locate the white OEM CAN Junction connector under the steering wheel, behind the kick panel.
  • ● Ensure vehicle is NOT powered on.
  • ● Slide the connector out of the holding junction by pushing the locking tab in the center and pulling downwards for easier access to wires.
B
Connection Guide
Wire Pairs (HEV models may have additional pairs) *Each two-wire column on the plug is a pair. HEV models may have additional pairs.
Identify High and Low Wires
Factory CAN Wire Main Harness
Blue (High) White (CAN-H)
White (Low) Yellow (CAN-L)
⚠️ IMPORTANT NOTE:
On some vehicle trims, colors may differ (e.g., blue & white / red & white). White wires away from the locking tab are always "CAN Low".
C
General Wire Taps Guide
Wire Taps Guide 1 Wire Taps Guide 2
  • ● Clamp: Take the wider end of the tap and wrap the jaws onto the vehicle data line. Clamp jaws tightly.
  • ● Insert: Insert the Power Step Main Harness signal wire into the narrow jaw.
  • ● Secure: Clamp the jaw tightly. Needle-nose pliers are highly recommended to ensure the metal blade pierces the insulation of both wires to make a proper connection.
⚠️ CRITICAL NOTE:
Make sure the wire is seated properly in the jaws before clamping. The wire being tapped must be centered on the "teeth" to make a proper tap. If wires are not fully secured, use a screwdriver to pry open the buckle, wrap the broken part with electrical tape, and re-do the tapping process.
🔩 Final Assembly
11
External Connections
12
Mounting the Boards
    Open the door to extend arms.
✅ Final System Check
How to Locate the CAN Bus Port | 2022+ Toyota Tundra (Gas & Hybrid)
Toyota Tundra (22-26)
Download
