Product Categories
🛠️ Preparation
Tools Required
  • Extensions & Wrenches
  • Needle Nose Pliers(Crucial)
  • Electrical Tape
Box Contents
See Photo
  • Running Boards (x2)
  • Linkage Assemblies (x4)
  • Hardware Kit
  • Harness & ECU
  • LED Lights
1
Pre-Assemble Brackets
  • Attach the mounting brackets to the linkage arms before putting them on the truck.
  • Fasten the linkage arms using M8 Flanged Nylon Lock Nuts.
  • Note: Tighten these fully now.
2
Install Driver Side Brackets
  • Locate the mounting studs on the rocker panel (under the doors).
  • Place a Plastic Insulator (F) over each stud first. This prevents corrosion and noise.
  • Mount the Front Bracket Assembly (A) and Rear Bracket Assembly (B) onto the studs.
  • Note: Do not fully tighten these nuts yet; leave them snug but adjustable for alignment.
3
Battery & Fuse Safety
  • Open the hood. Remove the 25A fuse from the Main Harness fuse holder.
    Do not skip this step (Safety against shorting).
  • Connect the Power Leads: Red (+) to Positive, Black (-) to Negative battery terminals.
  • Connect the ECU to the Main Harness.
    Secure the ECU near the battery using zip ties. Ensure it is mounted away from high-heat engine components.
4
Routing the Harness
  • Route the Main Harness (M) along the firewall and down the Driver-side wheel well.
  • Route the shorter leg of the harness down the Passenger-side wheel well.
  • Note: Use zip ties to secure wires away from hot or moving engine parts.
5
Penetrate to Cabin (Signal Wires)
  • Under the driver's side floor (behind the front wheel), locate the rubber floor grommet.
  • Poke a small hole through the grommet.
  • Thread the two signal wires (from the harness) up into the vehicle cabin.
  • Inside the truck, remove the driver's side kick panel and door sill plate. Peel back the carpet to locate the wires you just fed through.
Make or Break: This step allows the running boards to "read" your door signals. Please follow carefully.
A
Locate OBD-II & Identify
Locate OBD-II Port under steering wheel
  • Locate: Find the OBD-II Port under the steering wheel, near the front hood release lever.
  • Access: Unbolt the two flanged nuts using a socket for easier access to the rear side of the plug.
  • Identify Wires: Check the back of the OBD-II Connector configuration:
  • Single Row: If wires are in a single row (Smart Data Link Module), follow Part A .
  • Both Rows: If wires are connected to both rows (Standard OBD-II), follow Part B .
B
Connection Guide
Part A: Single Row Connector
Part A Single Row Connector
Signal Factory CAN Wire Main Harness
CAN LOW 6th from right, White Yellow
CAN HIGH 7th from right, Blue* White
*Note: On some vehicles, the Blue Wire may be White with a Blue Stripe.
Part B: Standard OBD-II (Two Rows)
Part B Two Rows Connector
CAN LOW 3rd from right (lower) Yellow
CAN HIGH 3rd from right (upper) White
Wire Taps Guide
Wire Taps Guide
  • Clamp: Wrap the wider jaw onto the vehicle data line.
  • Insert: Insert the Harness signal wire into the narrow jaw.
  • Secure: Clamp jaws tightly with needle-nose pliers. Ensure the wire is seated and centered on the teeth.
Finalizing:
After connecting, return the module back into place, tighten the nuts, and ensure it is secure.
🔩 Final Assembly
7
External Connections
  • Install LED Lights: Peel the adhesive backing and stick the LED lights to the rocker panel underside. Plug them into the harness.
  • Connect Harnesses: Under the vehicle, connect the Main Harness to the LED Y-Harnesses on both sides.
  • Plug in Motors: Connect the Y-Harness to the front motor plugs.
8
Mounting the Boards
  • Power Up: Re-insert the 25A fuse.
    Open the door to extend arms.
  • Mount Boards: Slide (4) M6 Carriage Bolts into the channels. Align with bracket slots. Secure with Washers and Nuts. Adjust position and tighten all nuts.
  • Reconnect: Plug the motor connector back in (or re-insert fuse). Close the door to retract the steps.
✅ Final System Check
2018 Ford F150 Install by @1194video
Ford F150 (15-20) | F250/F350/F450/F550 (17-19)
Download
