Ford Maverick (22-26) - Powered Retractable Bed Cover
Catalog
🛠️ Preparation
1
Unboxing & Inventory
Tonneau Cover Box Contents
2
PREP & DRILLING
Factory Tracks Replacement Tracks Front Drain Holes Power Harness Hole Rear Drain Holes
  • ● With Factory Tracks: Remove the plastic cap at the end of the side-mounted utility track and slide in four (4) 8mm threaded nut plates per side.
  • ● Without Factory Tracks: Install the included replacement tracks using three (3) 8-1.25mm x 25mm Torx bolts, flat washers, and lock washers into the threaded inserts in the side of the bed.
  • ● Front Drain Holes: Measure 2" (50mm) from the front bulkhead and 2" (50mm) from the base. Use a 19mm hole saw to drill the holes. Use a drill stop to avoid hitting the cab!
  • ● Power Harness Hole: (Driver Side Only) The power harness will route through the outer hole on the driver side bulkhead. Use a knife to cut a hole in the plastic plug large enough to fit the harness.
  • ● Rear Drain Holes: Drill one 19mm hole on each side, located in the raised section near the rear of the bed.
3
APPLY WEATHER SEALS
  • ● Clean Surfaces: Thoroughly clean the top of the plastic bed caps and the top of the front bed bulkhead of any dirt or debris.
  • ● Hard Foam Seal: Install the front bulkhead seal (hard foam seal) straight across the top of the front bulkhead.
  • ● Soft Foam Seals: Install the water-resistant seals (soft foam seals) across the top of the front bulkhead (right on top of the hard seal) and along the plastic bed caps. Position them as close to the inner edge of the bed as possible and trim off any excess.
  • ● Mastic Tape: Cut a piece from the included mastic tape roll, rub it into a strip with your hands, and press it firmly into the corners of the front bulkhead to improve water resistance.
4
INSTALL MOTOR
5
INSTALL SIDE RAILS
6
INSTALL CANISTER COVER PLATE
⚡Wiring & Routing
7
CONNECT WIRE HARNESS
    Use the fastening buckles to organize the wire harness neatly inside the canister area. Important: The connector for the power harness will remain unplugged at this time.
8A
ROUTE HARNESS (NON-HYBRID)
Remove Wheel Well Liner Remove Splash Guards Engine Bay Routing Underbody Routing Underbody Routing Underbody Routing Underbody Routing Underbody Routing
    Prep: Remove the rubber plug on the driver side of the bed. Temporarily remove the driver side rear wheel well liner (7 small tabs, 2 metal screws, 8 large inner tabs). Take care not to damage the green manual fuel door release!
    Engine Bay: Remove the bolts holding the outer edge of the underbody splash guards. Find a location behind the battery in the engine bay and lower the power harness down to the ground.
    Underbody Routing: Route the harness along the vehicle body underneath the splash guards towards the driver side rear wheel. Avoid any hot or moving parts.
    Into the Bed: Carefully route the harness up behind the wheel well liner and into the bed through the hole where the rubber plug was removed. Secure with wire ties and reinstall the liners/splash guards.
8B
ROUTE HARNESS (HYBRID)
Remove Wheel Well Liner Under Seat Battery Cut Cab Rubber Plug Route Through Cab Route Through Cab Route Through Cab Route Through Cab Route Through Cab Route Through Cab Route Through Cab Route Through Cab Route Through Cab
    Prep: Remove the rubber plug on the driver side of the bed. Temporarily remove the rear splash guard and wheel well liner in front of the driver side rear wheel.
    Locate Battery: The 12V battery is located under the passenger side rear seat. Lift the seat base and remove the plastic cover.
    Cab Penetration: Fold down the rear seat backrest to locate the rubber plug on the rear of the cab. Carefully cut a hole into this rubber plug. CAUTION: The vehicle's high power electrical harness (bright orange) also uses this plug. Do NOT damage it!
    Routing: Push the harness out of the cab through the cut hole, route it behind the wheel well liner, and up into the bed through the first hole. Inside the cab, tuck the harness behind the seats and under the plastic surrounding the battery.
🔌Bed Installation & Alignment
9
INSTALL TONNEAU COVER
    HEAVY LIFTING: With assistance, carefully lift the tonneau cover assembly and place it on top of the truck bed.
    Do not slide the tonneau cover along the bed as this will damage the foam seals you installed earlier.
    Leave the front of the tonneau cover about 1ft from the front of the bed and connect the power harness to the connector on the ECU main harness.
    Carefully lift the tonneau cover and position it as far forward as possible. Be careful not to pinch the wire harness. Leave a small gap between the canister and the front of the bed.
10A
BRACKETS (FACTORY TRACKS)
Bracket Overview Hardware Setup Outer Nut Plate Inner Nut Plate Final Assembly Final Assembly Final Assembly
    Start on the driver side. Insert two (2) 6mm T-channel blocks into the bottom channel of the side rail and position them near the front and rear.
    Use two (2) mount brackets. Attach them to the side rail using one (1) 6-1.00mm x 16mm T30 Torx bolt each.
    Attach the brackets to the 8mm threaded nut plates in the utility track using two (2) 8-1.25mm x 25mm T40 Torx bolts, lock washers, and flat washers.
    Support System: Place an outer double nut plate between the plastic and metal bed trim. Place an inner double nut plate behind the metal trim. Attach them to the main bracket using two (2) 6-1.00mm x 20mm T30 Torx bolts.
    Important: Leave all hardware loose. Repeat for passenger side.
10B
BRACKETS (NO FACTORY TRACKS)
No Factory Tracks Bracket Install 1 No Factory Tracks Bracket Install 2 No Factory Tracks Bracket Install 3 No Factory Tracks Bracket Install 4 No Factory Tracks Bracket Install 5 No Factory Tracks Bracket Install 6 No Factory Tracks Bracket Install 7
    Start on the driver side. Insert three (3) 6mm T-channel blocks into the bottom channel of the side rail.
    Align the blocks with the mount points on the replacement tracks (installed during Step 2).
    Use one (1) 6-1.00mm x 16mm T30 Torx bolt to attach each of the three (3) mount brackets to the side rail.
    Attach each mount bracket to the bed side using two (2) 8-1.25mm x 25mm T40 Torx bolts, flat washers, lock washers, and two (2) 8mm threaded mount blocks.
    Important: Leave all mount bracket hardware loose at this time. Repeat this process for the passenger side.
11
ALIGN THE SIDE RAILS
🔩Finalizing & Powering Up
11
INSTALL DRAIN TUBES
12
FINISH INSTALLATION
Install Guide
Download
What's Included
Download
How to Use
Download
