Chevy/GMC/Silverado 1500 - Powered Retractable Bed Cover
Catalog
🛠️ Preparation
1
Unboxing & Inventory
Tonneau Cover Box Contents
2
Prep the Truck Bed
Prep Bed Step 1 Prep Bed Step 2 Prep Bed Step 3 Prep Bed Step 4 Prep Bed Step 5 Prep Bed Step 6
  • ● Front Brackets: Measure 10.5" (167mm) from the front of the bed to mark the first hole on the plastic bed cap. Carefully drill a 1/4" (6mm) hole through the plastic only, avoiding the metal rail behind it. Repeat for all front bracket holes.
  • ● Apply Seals: Wipe down the front bulkhead and bed caps. Stick the hard foam seal across the front bulkhead. Then, stick the soft foam seals across the bulkhead (on top of the hard seal) and along the inner edges of the bed caps.
  • ● Mastic Tape: Roll a piece of mastic tape into a strip and press it firmly into the front bulkhead corners to improve water resistance.
  • ● Front Drain Holes: Use a 19mm hole saw to drill holes into the raised vertical ribs at the front of the bed.
    Driver side: 3-1/8" (80mm) from side, 4" (100mm) up.
    Passenger side: 6-1/2" (165mm) from side, 4" (100mm) up. Caution: Use a drill stop so you don't hit the cab!
  • ● Rear Drain Holes: Measure 2-1/2" (65mm) rearward from the center of the large stake pocket hole, and 17-1/2" (445mm) up from the base. Drill one 19mm hole on each side.
3
INSTALL MOTOR
4
INSTALL SIDE RAILS
5
INSTALL CANISTER COVER PLATE
⚡Wiring & Routing
6
CONNECT WIRE HARNESS
7
ROUTE THE POWER HARNESS
Routing Step 1 Routing Step 2 Routing Step 3 Routing Step 4
    Remove the plastic plug from the top driver side of the bed.
    Route the power harness out of the bed through this hole, down the length of the vehicle frame, up into the engine bay, and to the vehicle battery on the passenger side.
    Open the fuse holder cap, remove the fuse, and then connect the positive power harness connector to the main power harness. Do not connect power harness to the vehicle battery at this time.
SPECIAL NOTE: PASSENGER REAR BRACKET
Special Note Bracket Step 1 Special Note Bracket Step 2 Special Note Bracket Step 3 Special Note Bracket Step 3
    Drilling Required: A hole will need to be drilled for the upper mount point on the passenger side rear bracket.
    Mark the Spot: Once the hardware for the other mount points are installed and the bracket is securely in place, use the hole in the bracket to mark the location to drill.
    Drill & Treat: Remove the mount bracket and use a 10mm (3/8") drill bit to drill a hole in the side of the bed. Clean the edges of the hole and treat any exposed metal to prevent rust.
    Reinstall: Reinstall the mount bracket. Leave the hardware loose at this time.
🔌Bed Installation & Alignment
8
INSTALL TONNEAU COVER
    Grab a buddy and carefully lift the entire tonneau cover assembly onto the truck bed. Do not slide it along the bed rails, or you'll tear up those foam seals you just applied!
    Set it down leaving about a 1-foot gap from the front bulkhead.
    Plug the main power harness into the ECU connector.
    Carefully lift and nudge the cover as far forward as possible. Make sure to leave a slight gap between the canister and the front of the bed so they aren't rubbing.
9
INSTALL MOUNT BRACKETS
Front Bracket Install Rear Bracket Install Bracket Hardware Details Bracket Hardware Details
    Front Bracket: Insert five (5) 6mm T-channel blocks into the bottom channel of the side rail. Line up the front mount bracket with the holes on the truck bed side (clamping it temporarily helps).
    Use five (5) 6-1.00mm x 16mm T30 Torx bolts to attach the mount bracket to the side rail.
    Use three (3) 8-1.25mm x 25mm T40 Torx bolts, three (3) flat washers, three (3) lock washers, and three (3) threaded nut plates to attach the mount bracket to the bed side.
    Rear Bracket: Insert two (2) 6mm T-channel blocks into the channel behind the antenna. Use two (2) 6-1.00mm x 16mm T30 Torx bolts to attach the mount bracket to the side rail.
    Important: Leave all mount bracket hardware loose at this time. Repeat this entire process for the passenger side.
10
ALIGN THE SIDE RAILS
🔩Finalizing & Powering Up
11
INSTALL DRAIN TUBES
12
FINISH INSTALLATION
Install Guide
Download
What's Included
Download
How to Use
Download
