Toyota Tacoma (24-26) - Powered Retractable Bed Cover Installation Guide
Catalog
🛠️ Preparation
1
Unboxing & Inventory
Tonneau Cover Box Contents
2
PREP & DRILLING
Insert Threaded Blocks Front Drain Holes Power Harness Hole Rear Drain Holes Rear Drain Holes
  • ● Remove Original Parts: If the truck is equipped with bed-mounted utility tracks, remove them now. The utility tracks will not be reinstalled. Also, remove any reinforcement brackets located at the front corners of the bed.
  • ● Install Threaded Inserts: If your truck does not have threaded inserts installed, install the supplied 6mm inserts using the included tool. Each side requires six (6) inserts (two per mounting location).
  • ● Front Drain Holes: Measure 4 1/4" (108mm) from the side and 2" (50mm) up from the base. Use a 19mm hole saw to drill the drain tube holes into the raised vertical ribs on both sides.
  • ● Power Harness Hole: (Driver Side Only) Measure 4 1/4" (108mm) from the side and 5" (127mm) up from the base. Use a 16mm (5/8") drill bit to drill the hole. Caution: Use a drill stop to avoid hitting the cab!
  • ● Rear Drain Holes: Locate the upper, innermost indentation approx. 9 1/4" (235mm) from the base of the bed. Use a 19mm hole saw to drill one hole on each side.
3
APPLY WEATHER SEALS
  • ● Clean Surfaces: Thoroughly clean the top of the plastic bed caps and the top of the front bed bulkhead of any dirt or debris.
  • ● Hard Foam Seal: Install the front bulkhead seal (hard foam seal) straight across the top of the front bulkhead.
  • ● Soft Foam Seals: Install the water-resistant seals (soft foam seals) across the top of the front bulkhead (right on top of the hard seal) and along the plastic bed caps. Position them as close to the inner edge of the bed as possible and trim off any excess.
  • ● Mastic Tape: Cut a piece from the included mastic tape roll, rub it into a strip with your hands, and press it firmly into the corners of the front bulkhead to improve water resistance.
4
INSTALL MOTOR
5
INSTALL SIDE RAILS
6
INSTALL CANISTER COVER PLATE
⚡Wiring & Routing
7
CONNECT WIRE HARNESS
8
ROUTE THE POWER HARNESS
Routing Step 1 Routing Step 2 Routing Step 3 Routing Step 4 Routing Step 5 Routing Step 6
    Dedicated Routing Hole: The tonneau cover power harness must be routed out through the 16mm (5/8") hole on the driver side of the bed that was drilled previously in Step 2.
    From there, the harness will travel down the length of the vehicle frame, up into the engine bay, and to the vehicle battery on the passenger side.
    Open the fuse holder cap, remove the fuse, and then connect the positive power harness connector to the main power harness. Do not connect the power harness to the vehicle battery at this time.
🔌Bed Installation & Alignment
9
INSTALL TONNEAU COVER
    Grab a buddy and carefully lift the entire tonneau cover assembly onto the truck bed. Do not slide it along the bed rails, or you'll tear up those foam seals you just applied!
    Set it down leaving about a 1-foot gap from the front bulkhead.
    Plug the main power harness into the ECU connector.
    Carefully lift and nudge the cover as far forward as possible. Make sure to leave a slight gap between the canister and the front of the bed so they aren't rubbing.
10
INSTALL MOUNT BRACKETS
Front/Center Bracket Overview Front/Center Hardware Remove Rear Factory Bolts Rear Bracket Install Rear Bracket Install5 Rear Bracket Install6
    Front & Center Brackets: Insert two (2) 6mm T-channel blocks into the bottom channel of the side rail. Attach the bracket to the side rail using one (1) 6-1.00mm x 16mm T30 Torx bolt.
    Attach the front/center brackets to the truck bed using two (2) 8-1.25mm x 25mm T40 Torx bolts, lock washers, and flat washers. These bolts will thread into the 8mm mount blocks you installed in the utility track during Step 2.
    Rear Bracket: First, remove the two factory bolts located at the top rear of the bed. Insert one (1) 6mm T-channel block into the side rail.
    Attach the Rear Mount Bracket to the side rail using one (1) 16mm Torx bolt. Attach it to the bed using one (1) 20mm Torx bolt and one (1) 35mm Torx bolt.
    Important: Leave all mount bracket hardware loose at this time. Repeat this entire process for the passenger side.
11
ALIGN THE SIDE RAILS
🔩Finalizing & Powering Up
11
INSTALL DRAIN TUBES
12
FINISH INSTALLATION
Install Guide
Download
What's Included
Download
How to Use
Download
