Ram 1500 - Power Running Boards Installation Guide
Product Categories
🛠️ Preparation
Tools Required
  • Extensions & Wrenches
  • Needle Nose Pliers(Crucial)
  • Electrical Tape
Box Contents
See Photo
  • Running Boards (x2)
  • Linkage Assemblies (x4)
  • Hardware Kit
  • Harness & ECU
  • LED Lights
Step 1: Check Vehicle Frame Modules
  • If vehicle has ATMM Modules or Mass Dampers on the front frame, follow Step 1A.
  • If vehicle does NOT have these modules, proceed directly to Step 1B.
1A
Relocate ATMM / Damper
Locate ATMM Module
Relocation Bracket
Mass Damper Variant
  • ● Unplug & Remove: Locate Driver Side ATMM/Damper on the frame. Unplug and unbolt it. WARNING Removing ATMM entirely may cause excess vibration.
  • ● Prep Relocation Bracket: Insert M8 Carriage bolts (J) through the square holes on the Relocation Bracket (K) and secure using Plastic Retainers (F).
  • ● Mount: Mount the ATMM/Damper onto the relocation bracket using M8 Nylon Lock Nuts (I). Then mount the Relocation Bracket (K) onto the frame where the OE module was.
  • ● NOTE On some models (e.g., TRX), an OE plug may be in the way. Unbolt it and secure it elsewhere using zip ties.
1B
Pre-Assemble Brackets
  • ● Take the mounting brackets and attach them to the aluminum linkage arms.
  • ● Insert M8 Carriage Bolts into the square slots on the brackets so that the threads are pointing downwards.
  • ● Use the M8 Flanged Nylon Lock Nuts to fasten the arms to the brackets. There are 4 fastening points on each bracket.
  • ● CRITICAL Tighten the M8 Flanged Nylon Lock Nuts all the way until tight.
2
Mount Front Bracket
Line up bracket slots to studs
Front Bracket Mounted
  • ● Line up front mounting bracket slots to the studs on the rocker panel.
  • ● Place the Driver Side/Left Front Bracket Assembly (A) onto the rocker panel.
  • ● Fasten using Nylon Lock Nuts (I) and washers (H). Do not tighten all the way yet.
  • ● NOTE Cleaning OE threads using a tap/die before installing the bracket is highly recommended.
3
Mount Rear Bracket
Line up rear bracket slots
Rear Bracket Mounted
  • ● Locate rear mounting points. Line up the rear mounting bracket slots to the studs.
  • ● Place the Driver Side/Left Rear Bracket Assembly (B) onto the rocker panel.
  • ● CRITICAL Do not tighten all the way yet. Adjustments may be needed later.
1A
Locate ATMM Module
Relocation Bracket
Mass Damper Variant
1B
2
Mount Front Bracket
3
Mount Rear Bracket
Step 9: Routing Check & Vehicle Year Branch
After routing the Main Harness (M), check to make sure wires are secure with cable ties. Avoid contact with moving/hot engine components and the vehicle suspension.
  • 2019-2024 Models: Proceed to Step 10A (Part A below).
  • 2025 Models: Proceed to Step 10B (Part B below).
    *Confirm model year before proceeding (some 2025 models were manufactured in 2024).
Part A: 2019-2024 Models (Step 10A)
A1
Access Green CAN Hub
Peel weather strip and remove panel
Locate green CAN wiring hub
Pull plastic hub out
  • ● On the front Driver Side door, peel the weather strip from the seams and use a pry tool to remove the side dash panel.
  • ● Locate the green CAN wiring hub on the backside of the metal framework.
  • ● Remove the entire black plastic casing (with green hub attached) by pulling it up. (Note: A plastic detent may need to be pressed to unhook it).
A2
19-24 Connection Guide
Identify Plugs
Identify top row 2-wire plug On the top row with empty slots, select the leftmost plug with two wires extending from it.
Wire Colors
High and Low Wires The wire on the bottom is CAN High. The wire on top is CAN Low.
Factory CAN Wire Main Harness
Orange w/ White Stripe White (High)
Yellow Yellow (Low)
⚠️ Note: Colors may differ from vehicle to vehicle. Always use the OE plug as a reference point (Bottom = High, Top = Low). If the indicated colors are not present, tap any of the pairs of wires on the upper row.
Part B: 2025 Models (Step 10B)
B1
Locate CAN Bus Plug
Driver Side under steering wheel
Large CAN bus connector
  • ● On the Driver Side (under the steering wheel, near the kick panel), locate the large CAN bus connector close to the firewall.
B2
2025 Connection Guide
Identify Twisted Pair
Identify twisted pair on bottom right Identify the configuration on the bottom side of the plug. On the right side, select the twisted pair.
Wire Colors
White and Blue with White stripe wires
Blue w/ White Stripe White (High)
White Yellow (Low)
⚠️ Note: Always use the OE plug as a reference point. After successfully connecting, secure wires so they do not interfere with the brake pedal.
Part C: General Wire Taps Guide (Step 11)
11
How to use "Shark Taps"
Wire Taps Guide 1 Wire Taps Guide 2
  • ● Clamp: Take the wider end of the tap and wrap the jaws onto the vehicle data line. Clamp jaws tightly.
  • ● Insert: Insert the Power Step Main Harness signal wire into the narrow jaw.
  • ● Secure: Clamp the jaw tightly. Needle-nose pliers are highly recommended to ensure the metal blade pierces the insulation of both wires to make a proper connection.
⚠️ CRITICAL NOTE:
Make sure the wire is seated properly in the jaws before clamping. The wire being tapped must be centered on the "teeth" to make a proper tap. If wires are not fully secured, use a screwdriver to pry open the clamping buckle, wrap the broken part with electrical tape, and re-do the tapping process.
🔩 Final Assembly
12
External Connections
13
Mounting the Boards
    Open the door to extend arms.
✅ Final System Check
How to Locate the CAN Bus Port | 2019-2024 Ram 1500
Ram 1500 (19-24) | 1500 TRX (19-23)
Download
