Chevy Silverado/GMC Sierra 15 (24-26) - Power Running Boards Installation Guide
Product Categories
🛠️ Preparation
Tools Required
  • Extensions & Wrenches
  • Needle Nose Pliers(Crucial)
  • Electrical Tape
Box Contents
See Photo
  • Running Boards (x2)
  • Linkage Assemblies (x4)
  • Hardware Kit
  • Harness & ECU
  • LED Lights
1
Install Front Bolt Plate
Locate Driver Side Front Mounting Points
  • ●Locate Driver Side front mounting points on the rocker panel under the front door. Remove any OE plastic insert caps.
  • ●Insert the Bolt Plate (J) into the upper left hole, ensuring bolt threads face the frame.
  • ●Use the plastic retainer (F) to secure the bolt plate in place.
  • ●TIP A pry-tool is recommended for removing plastic insert caps.
2
Pre-Assemble Brackets
  • ●Take the mounting brackets and attach them to the linkage arms.
  • ●Insert M8 Carriage Bolts into the square slots on the brackets, with threads pointing downwards.
  • ●Fasten the aluminum linkage arms to the brackets using M8 Flanged Nylon Lock Nuts (4 fastening points per bracket).
  • ●NOTE Tighten the M8 Flanged Nylon Lock Nuts all the way until tight.
3
Mount Front Bracket
Front Bracket Mounting Point - Perspective from front
Front Bracket Mounting Point - Perspective from back
Front Bracket Installed View
  • ●Line up front mounting bracket slots to the rocker panel threaded inserts.
  • ●Place the Driver Side/Left Front Bracket Assembly (A) onto the rocker panel.
  • ●Fasten using 8mm Bolts, Lock Washers, and Flat Washers into the OE inserts, and an 8mm Hex Nut to the Bolt Plate.
  • ●NOTE Do not tighten all the way yet. Adjustments may be needed later.
4
Mount Rear Bracket
Locate Rear Mounting Points
Rear Bracket Installed View
  • ●Locate rear mounting points and remove appropriate plastic OE insert protectors.
  • ●Line up bracket slots to studs and place Driver Side/Left Rear Bracket Assembly (B) onto rocker panel. Remove any obstructing rubber plugs.
  • ●Fasten using 8mm bolts (K), lock washers (L), and flat washers (H). Do not fully tighten yet.
  • ●NOTE The more forward pair of inserts are additional mounting points (not on all vehicles). If present, use them for extra strength. If not, use just the rearward 2 mounting points.
6
Battery & Power Connection
Remove 25A Fuse
Connect to Battery Terminals
  • ● Remove Fuse: Open the front hood. Remove the 25A fuse from the main harness fuse box.
    WARNING Do not skip this step to prevent electrical sparks and shorting.
  • ● Power Leads: Connect the Positive (Red) lead to the positive battery terminal, and the Negative (Black) lead to the negative terminal. Ensure both are secure.
  • ● Connect ECU: Connect the ECU (P) to the main harness.
7
Routing & ECU Mounting
Harness Routing Diagram
  • ● Route Harness: Route the main harness down the Driver-side wheel well. Route the shorter leg down the Passenger-side wheel well.
    Avoid contact with moving or hot engine components. Secure with supplied cable ties.
  • ● Mount ECU: Use the 5 included double-sided adhesive tapes to secure the ECU. Secure it near the battery or any space away from direct engine heat.
8A
Cabin Routing (Standard Models)
Driver Side Grommet
Feed wires under carpet
For most standard models
  • ● Access Grommet: On the underside of the Driver Side, locate and remove the floor grommet in the floor panel behind the front linkage arm.
  • ● Thread Wires: Poke a hole through the grommet and thread the two signal wires up into the vehicle cabin.
  • ● Inside Cabin: Remove the driver-side front kick panel and bottom door sill plate. Peel back the carpet to locate and pull the wires through.
8B
Cabin Routing (Specific Models)
Passenger side plastic cap
Feed wires through passenger side
ONLY FOR: 22+ Silverado 1500 & 24+ Silverado 2500/3500
  • ● Reroute Harness: For the specific models listed above, route the signal branch of the main harness through the Passenger Side instead of the Driver Side.
  • ● Locate Cap: Find the plastic cap on the underside of the passenger side floor panel.
  • ● Penetrate: Poke a hole using a drill or punch through the plastic cap to feed the wires into the cabin.
9
Motor Connection
Connect LED Harness to Motor
  • ● Attach Harness: Attach the main harness (M) to the LED Y-Harness (N).
  • ● Connect Driver Side: Attach the LED Y-Harness (N) to the motor on the Driver Side.
  • ● Connect Passenger Side: Repeat the process for the Passenger Side.
  • ● NOTE The shorter LED Y-Harness should connect to the motor that is on the same side as the ECU.
Step 10: Determine Your Technology System
  • Pre-refresh System (Follow Part A below):
    19-21 Silverado/Sierra 1500 & 20-23 Silverado/Sierra 2500-3500 HD.
    22 Silverado 1500 LTD & 22 Sierra 1500 Limited.
  • Post-refresh System (Follow Part B below):
    22+ Silverado/Sierra 1500 & 24+ Silverado/Sierra 2500-3500 HD.
Part A: Pre-refresh Technology System
A1
Locate OBD-II Port
Locate OBD-II Port
  • ● Locate: Find the OBD-II Port under the steering wheel, near the front hood release lever.
  • ● Access: Unbolt the two bolts using a socket for easier access to the rear side of the plug where the wires are located.
A2
OBD-II Connection Guide
Part A Wiring
Signal Factory Wire Main Harness
CAN LOW 3rd from right (lower) Yellow
CAN HIGH 3rd from right (upper) White
Note: On some vehicles, wire colors may differ. Rely on the pin position. After connecting, return the module back into its place and tighten the bolts.
Part B: Post-refresh Technology System
B1
Locate Radio Module
Locate Radio Module
  • ● Locate: Under the glove compartment on the Passenger Side, locate the radio module.
  • ● Access: On some models, the underside shield may need to be removed to access the components.
  • ● Identify Plug: Determine your radio type by looking at the two main connectors.
    If you have a GREEN and GREY plug, follow B-1.
    If you have a BLACK and GREY plug, follow B-2.
B2
Radio Connection Guide
B-1: GREEN and GREY plug
Part B1 Wiring Pin 16 = Blue w/ White Stripe (Connect to White). Pin 4 = Blue w/ Yellow Stripe (Connect to Yellow).
B-2: BLACK and GREY plug
Part B2 Wiring Pin 9 = Blue w/ White Stripe (Connect to White). Pin 10 = Blue w/ Yellow Stripe (Connect to Yellow).
CAN HIGH Blue/White Stripe White
CAN LOW Blue/Yellow Stripe Yellow
Note: On some vehicles, the positions of the plugs may be reversed. After connecting, return the module back and tighten.
Part C: General Wire Taps Guide
C
How to use "Shark Taps"
Wire Taps Guide 1 Wire Taps Guide 2
  • ● Clamp: Take the wider end of the tap and wrap the jaws onto the vehicle data line. Clamp jaws tightly.
  • ● Insert: Insert the Power Step Main Harness signal wire into the narrow jaw.
  • ● Secure: Clamp the jaw tightly. Needle-nose pliers are highly recommended to ensure the metal blade pierces the insulation of both wires to make a proper connection.
⚠️ CRITICAL NOTE:
Make sure the wire is seated properly in the jaws before clamping. The wire being tapped must be centered on the "teeth" to make a proper tap. If wires are not fully secured, use a screwdriver to pry open the buckle, wrap the broken part with electrical tape, and re-do the tapping process.
🔩 Final Assembly
11
External Connections
12
Mounting the Boards
    Open the door to extend arms.
✅ Final System Check
How to Locate the CAN Bus Port | 2022+ Chevy Silverado 1500/2500/3500
Chevy/GMC 1500 (22-26) | Chevy/GMC 2500 HD/3500 HD (24-25)
Download
