Engine Bay Wiring
- ● SAFETY FIRST Remove the fuse from the wiring harness before you begin routing or connecting any cables. Use the 10AWG wire.
- ● Positive Connection: Crimp the supplied copper terminal onto the red positive lead of the harness, then connect it to the positive terminal of your vehicle's battery.
- ● Chassis Grounding: Connect the black negative lead to a solid, paint-free chassis ground point nearby. Avoid running negative leads directly to the battery if a suitable chassis ground is available.
- ● Secure the wiring harness in the engine bay using zip ties, ensuring it's clear of any moving parts or extreme heat sources.
