Toyota Tundra (07-21) Powered Retractable Bed Cover Installation Guide
Catalog
🛠️ Preparation
1
Unboxing & Inventory
Tonneau Cover Box Contents
2
PREP & DRILLING
Remove Front Utility Track Insert Threaded Blocks Front Drain Holes Power Harness Hole Rear Drain Holes Rear Drain Holes6 Rear Drain Holes7 Rear Drain Holes8
  • ● Remove Front Utility Track: Remove the front bed utility track (4 T30 bolts + center plastic tab). Slide the track toward the driver side to disengage the tab. It will not be reinstalled.
  • ● Install Threaded Blocks: Remove the plastic cap at the end of the side mounted utility track and slide in six (6) 8mm threaded mount blocks per side.
    *(If your truck doesn't have side tracks, install the included replacement tracks first).*
  • ● Front Drain Holes: The front drains use the inner set of holes at the base of the bulkhead. Use a 19mm hole saw to cut through the plastic plugs covering these holes.
  • ● Power Harness Hole: (Driver Side Only) Use a knife to cut a hole in the outer plastic plug large enough to pass the power harness through. No metal drilling is required here.
  • ● Rear Drain Holes: Drill one 19mm hole on each side, located in the raised section near the rear of the bed.
3
APPLY WEATHER SEALS
  • ● Clean Surfaces: Thoroughly clean the top of the plastic bed caps and the top of the front bed bulkhead of any dirt or debris.
  • ● Hard Foam Seal: Install the front bulkhead seal (hard foam seal) straight across the top of the front bulkhead.
  • ● Soft Foam Seals: Install the water-resistant seals (soft foam seals) across the top of the front bulkhead (right on top of the hard seal) and along the plastic bed caps. Position them as close to the inner edge of the bed as possible and trim off any excess.
  • ● Mastic Tape: Cut a piece from the included mastic tape roll, rub it into a strip with your hands, and press it firmly into the corners of the front bulkhead to improve water resistance.
4
INSTALL MOTOR
5
INSTALL SIDE RAILS
6
INSTALL CANISTER COVER PLATE
⚡Wiring & Routing
7
CONNECT WIRE HARNESS
8
ROUTE THE POWER HARNESS
Routing Step 1 Routing Step 2 Routing Step 3 Routing Step 4 Routing Step 5 Routing Step 6
    Dedicated Routing Hole: The tonneau cover power harness must be routed out through the hole on the driver side of the bed. Pass it through the cut made in the plastic plug during Step 2.
    From there, the harness will travel down the length of the vehicle frame, up into the engine bay, and to the vehicle battery on the passenger side.
    Open the fuse holder cap, remove the fuse, and then connect the positive power harness connector to the main power harness. Do not connect the power harness to the vehicle battery at this time.
🔌Bed Installation & Alignment
9
INSTALL TONNEAU COVER
    HEAVY LIFTING: With assistance, carefully lift the tonneau cover assembly and place it on top of the truck bed.
    Do not slide the tonneau cover along the bed as this will damage the foam seals you installed earlier.
    Leave the front of the tonneau cover about 1ft from the front of the bed and connect the power harness to the connector on the ECU main harness.
    Carefully lift the tonneau cover and position it as far forward as possible. Be careful not to pinch the wire harness. Leave a small gap between the canister and the front of the bed.
10A
BRACKETS (FACTORY TRACKS)
Factory Tracks Bracket Install 1 Factory Tracks Bracket Install 2 Factory Tracks Bracket Install 3
    Start on the driver side. Insert three (3) 6mm T-channel blocks into the bottom channel of the side rail and space them out evenly along the length of the rail.
    Use three (3) mount brackets to attach the tonneau cover to the truck bed. Use one (1) 6-1.00mm x 16mm T30 torx bolt to attach each mount bracket to the side rail.
    Use two (2) 8-1.25mm x 25mm T40 torx bolts, lock washers, and flat washers to attach each mount bracket to the 8mm threaded blocks that were previously installed in the factory utility track.
    Important: Leave all hardware loose. Position the front bracket as far forward and the rear bracket as far rearward as possible along the utility track. Repeat for passenger side.
10B
BRACKETS (NO FACTORY TRACKS)
No Factory Tracks Bracket Install 1 No Factory Tracks Bracket Install 2 No Factory Tracks Bracket Install 3 No Factory Tracks Bracket Install 4
    Start on the driver side. Insert three (3) 6mm T-channel blocks into the bottom channel of the side rail.
    Align the blocks with the mount points on the replacement tracks (installed during Step 2).
    Use one (1) 6-1.00mm x 16mm T30 Torx bolt to attach each of the three (3) mount brackets to the side rail.
    Attach each mount bracket to the bed side using two (2) 8-1.25mm x 25mm T40 Torx bolts, flat washers, lock washers, and two (2) 8mm threaded mount blocks.
    Important: Leave all mount bracket hardware loose at this time. Repeat this process for the passenger side.
11
ALIGN THE SIDE RAILS
🔩Finalizing & Powering Up
11
INSTALL DRAIN TUBES
12
FINISH INSTALLATION
Install Guide
Download
What's Included
Download
How to Use
Download
