Catalog
🛠️ Preparation
Tools Required
  • Extensions & Wrenches
  • Needle Nose Pliers(Crucial)
  • Electrical Tape
Box Contents
See Photo
  • Running Boards (x2)
  • Linkage Assemblies (x4)
  • Hardware Kit
  • Harness & ECU
  • LED Lights
1
Pre-Assemble Brackets
  • ● Attach the mounting brackets to the linkage arms before putting them on the truck.
  • ● Fasten the linkage arms using M8 Flanged Nylon Lock Nuts.
  • ● Note: Tighten these fully now.
2
Install Driver Side Brackets
  • ● Locate the mounting studs on the rocker panel (under the doors).
  • ● Place a Plastic Insulator (F) over each stud first. This prevents corrosion and noise.
  • ● Mount the Front Bracket Assembly (A) and Rear Bracket Assembly (B) onto the studs.
  • ● Note: Do not fully tighten these nuts yet; leave them snug but adjustable for alignment.
3
Battery & Fuse Safety
  • ● Open the hood. Remove the 25A fuse from the Main Harness fuse holder.
    Do not skip this step (Safety against shorting).
  • ● Connect the Power Leads: Red (+) to Positive, Black (-) to Negative battery terminals.
  • ● Connect the ECU to the Main Harness.
    Secure the ECU near the battery using zip ties. Ensure it is mounted away from high-heat engine components.
4
Routing the Harness
  • ● Route the Main Harness (M) along the firewall and down the Driver-side wheel well.
  • ● Route the shorter leg of the harness down the Passenger-side wheel well.
  • ● Note: Use zip ties to secure wires away from hot or moving engine parts.
5
Penetrate to Cabin (Signal Wires)
  • ● Under the driver's side floor (behind the front wheel), locate the rubber floor grommet.
  • ● Poke a small hole through the grommet.
  • ● Thread the two signal wires (from the harness) up into the vehicle cabin.
  • ● Inside the truck, remove the driver's side kick panel and door sill plate. Peel back the carpet to locate the wires you just fed through.
Make or Break: This step allows the running boards to "read" your door signals. Please follow carefully.
A
Locate & Identify
  • ● Locate BCM: It is the black module under the steering wheel, directly behind the OBD-II port.
  • ● Access: Press the center locking tab and slide the module outwards to reveal the black plug.
  • ● Identify Wires: Look for the twisted pair on the Black Plug.You need to find two specific twisted wires:
    CAN High: Green wire with a Blue Stripe.
    CAN Low: White wire with a Green Stripe.
  • ● Note: Wire colors may vary slightly on newer models. Rely on the pin position if colors act differently.
B
Connection Guide
See Photo
Signal Factory Wire Wolfbox Wire
CAN HIGH Green/Blue White
CAN LOW White/Green Yellow
How to use Shark Taps:
1. Clamp: Place the factory wire inside the wider channel of the tap.
2. Insert: Slide the Wolfbox signal wire into the narrow channel.
3. Secure: Use needle-nose pliers to press the metal blade down firmly. It must pierce the insulation of both wires to make a connection.
Boards Won't Move?
The CAN High/Low signals might be reversed. Try swapping the connections (Connect Wolfbox White to Factory White/Green, and Wolfbox Yellow to Factory Green/Blue). This is a common fix.
Wolfbox Wiring Diagram Close-up
🔩 Final Assembly
7
External Connections
8
Mounting the Boards
    Open the door to extend arms.
✅ Final System Check
How to install
Wolfbox power running board Instruction
Download
